Apr 27, 2018, 10:54 AM
X6B Receiver - Does it work with fixed wing airplane ?
I am thinking about getting Flysky FS-i6X radio from Banggood and will be using it with fixed wing airplanes.
Does the Flysky X6B Receiver works with fixed wing airplanes?
I only need 4 channels.
Apr 30, 2018, 06:50 AM
Fan of just about anything RC
SoloProFan's Avatar
You can connect it PPM, iBus and PWM. For controlling servos etc, without a flight controller, I suppose PWM is the best option. Just connect signal wires 1-4 to the servos and the speed controller, if it's an electric plane, and power the servos directly from battery or BEC, so their current draw won't kill the receiver.
Latest blog entry: For the love of the hobby!
Apr 08, 2019, 10:20 AM
Hello,
I am in the same situation as the OP but I dont understand exactly what you mean.
Usually the servos are directly connected to the receiver - so what do I need to do different?
Why would the servos kill the receiver?
With kind regards
Apr 08, 2019, 02:30 PM
SoloProFan's Avatar
Originally Posted by Salus
Hello,
With kind regards
Receivers that allow to directly connect the servos are generally bigger, with wider traces, to allow more current to flow. The X6B isn't that big, and doesn't seem to be intended to power a larger number of servos, especially some bigger ones. If too much current is forced to flow through the tiny circuit board of the X6B. it might get damagea. Which is why I suggested to connect the servos directly to a power source, and only connect the signal wire for each receiver's PWM channel to the servos. Since you will have to be creative with wiring anyway, since the receiver doesn't have servo connectors.
Help! Does spektrum DM9 module work with AR9030T receiver? kevinlai518 Radios 2 Nov 19, 2017 10:37 PM
Careful! Naze32 Acro rev6 + GPS: works with INAV, does not work with Cleanflight Florin Andrei Beginner Multirotor Drones 2 Jun 11, 2017 11:45 PM
Help! KK2.1.5 gyro board for fixed wing airplane SBeinker FPV Equipment 0 Jan 05, 2016 12:12 PM
Help! Flight controller for FPV airplane (fixed-wing) dcg9381 FPV Talk 8 Oct 19, 2015 08:43 PM
Discussion Does Esky 0406A work with airplanes? akvik Beginner Training Area (Aircraft-Electric) 1 Apr 14, 2008 04:14 PM
