Apr 26, 2018, 06:57 PM
Mini Apprentice Set up
Iíve got everything set up and it flyís great. Butó when I switch from beginner mode to intermediate the plane immediately dives. The CG seems correct and the elevator is trimmed level. Is this normal? All is done at half throttle.
Apr 26, 2018, 08:23 PM
putput's Avatar
In beginner mode the self leveling feature will keep the plane flying. You need to do a couple things. First make sure your cg is set correct. The factory settings are great. Now try again. If still diving, then you need to manually adjust the elevator linkage until it doesn't dive in intermediate or advanced modes. Go high and test. If it does then bring it back down, adjust the elevator up a couple turns and try again
Apr 26, 2018, 09:00 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Screenshot from the manual ↓ .
Apr 27, 2018, 12:00 AM
If I correct and adjust to fly level in experience mode will it still fly level in safe mode like it does now?
Apr 27, 2018, 12:52 AM
With the transmitter on , the battery plugged in , and the SAFE set to experienced mode ..... adjust all the control surfaces so they're centered . Make the adjustments by turning the clevises to change the length of the linkages ( as shown in the manual's screenshot above ) .
Then when you fly in beginner mode the plane will fly level , and when you switch to intermediate or experienced mode the plane will still fly level .
Apr 27, 2018, 07:49 AM
Perpetual Noob
BoxCar31's Avatar
To get an idea of how much you need to adjust the clevises, use the trim adjustment to align the elevator to the stabilizer. The amount of change in the servo arm from center will show how much the clevis needs to lengthen or shorten the control rod. The same procedure can be used to adjust the rudder/nose gear.
Apr 27, 2018, 09:58 PM
Thanks for the quick replies. Now need a calm day to do some adjusting.
Discussion Mini Lap Counter Set Up legacygt777 Micro Cars 7 May 29, 2017 12:24 PM
Discussion Battery reciever set up for mini DLG and Gubby from hooby king ell198679 Slope 2 Jan 31, 2016 06:28 PM
Mini-HowTo Flip32 mini set up dumbthumbsrc Beginner Multirotor Drones 2 Jan 22, 2016 02:35 PM
Discussion CC3D set-up for mini (Spedix S250) HEX Herrsavage Multirotor Drone Electronics 8 Dec 14, 2015 02:58 AM
