Fly Fast with the new E-flite V900
The V900 is the fastest prop-driven E-flite airplane yet! Right out of the box it can reach top speeds of 120+ MPH on 4S, and even 100+ MPH on 3S, without the need for upgrades or prop changes.
The V900 high-speed sport airplane is the fastest prop-driven E-flite airplane to date!
Right out of the box it can reach top speeds of 120+ MPH on 4S, and even 100+ MPH on 3S, without the need for upgrades or prop changes. It’s designed to whip heads by flying fast and looking good with slick aerodynamics, composite reinforced EPO construction and a vibrant trim scheme that stands out on the ground and in the air.
If you have a need for speed—adrenalin pumping, righteous SPEED—then you’re going to love the E-flite® V900 airplane. The factory-installed high-power brushless motor and 60-amp ESC deliver unlimited vertical performance and incredible top speeds up to 120+ MPH without the need for upgrades or modifications. The lightweight yet stiff and durable airframe is equipped with digital, metal-geared servos to offer precision and reliability you’ll appreciate flight after flight. No glue is required for assembly, and you can be flying in just the time it takes to charge a battery. So whether you’re an intermediate pilot and this is your first high-speed airplane, or you’re an experienced speed addict, you can be in the air and flying FAST in almost no time at all. But the V900 airplane doesn’t just fly fast—it’s well-behaved and slows down nicely for smooth approaches and landings, plus it’s capable of aerobatics including huge loops, rolls, knife edge and more.
Versatile Brushless Power
The V900 is factory-equipped with a versatile high-power brushless power system that gives you the option to choose just how fast you want to go. Simply drop in a 3S battery to reach speeds up to 100+ MPH. Or, to go beyond that and reach top speeds up to 120+ MPH, install a 4S battery—no modifications or upgrades are necessary—not even a prop change is required.
Specs
  • Completion Level: Bind-N-Fly Basic
  • Flying Weight: 840g (29.7 oz)
  • Length: 31.8 Iin (808.5mm)
  • Material: Foam
  • Minimum Required Radio: 4+ channel
  • Motor Size: 15 Bl outrunner 1260kV
  • Wing Area: 203.7 Sq In (13.1 Sq Dm)
  • Wingspan: 35.4 in (900mm)
Photos
Speed is nothing without the right balance of strength and precise control. The V900’s stunning and sleek airframe is molded in EPO that’s composite reinforced so it’s stiff and durable, yet is also lightweight. Plus it’s equipped with digital, metal-geared servos that deliver the precise control and reliability you need to enjoy flying FAST flight after flight.
Strength and Precision
No glue is required for assembly, and the V900 can be ready to fly in the time it takes to charge a battery. The compact size makes it easy to transport and store, or you can easily install and remove the carbon-fiber reinforced, one-piece wing if needed. The wing also features an integrated and reinforced grip for easier hand launches and added protection when landing.
Learn More!
Head over to the Horizon site for more info and pricing!
Apr 26, 2018, 03:55 PM
RCG Admin
Jason Cole's Avatar
That's HOT!
Apr 26, 2018, 04:38 PM
C.H.E.A.P.
MICKEL's Avatar
EFXtra pilots, watch out!
Apr 26, 2018, 06:29 PM
Hugo Flynow's Avatar
I like it!
Apr 26, 2018, 06:35 PM
Can it be Hovered.....LOL......
Apr 26, 2018, 06:47 PM
C.H.E.A.P.
MICKEL's Avatar
LOL, I tried to hover a Green Goblin today (EFXtra); it doesn't like it too much.
Apr 26, 2018, 07:51 PM
Pile-it
Alien_Tech's Avatar
Whats the deal with variable wing span?
Apr 26, 2018, 08:01 PM
Sucker for biplanes
DMHIGHFLYER's Avatar
Release date?
Apr 26, 2018, 08:41 PM
Go to website,,,,all will be reveled
Apr 26, 2018, 09:29 PM
Wing Commander of 50+ Aircraft
Area81Racing's Avatar
$ 159.00 PNP, and $ 179.00 with the AS3X receiver.....NICE!
Apr 26, 2018, 11:14 PM
FoxProGT's Avatar
Sweet indeed!
Apr 26, 2018, 11:24 PM
Andi Susanto
excusme sir,i new member in this group...can you help me to get the pdf file about this plane?....thanks
Apr 27, 2018, 12:04 AM
Like the AS3X for the stability and the SAFE for hand launching.
Apr 27, 2018, 02:29 AM
Me likey.
But I'm sure me will not likey the price in Europe...
New Product E-flite® F4U-4 Corsair 1.2m Bind-N-Fly® Basic ChuckTseeker Electric Warbirds 2374 Oct 18, 2021 04:39 PM
Question E-Flite or FMS Warbird to fly off of grass field. kid at 55 Electric Warbirds 7 May 21, 2017 02:55 PM
Discussion Anyone with Phoenix fly the E-flite stearman model? Ara Tidwell Simulators 12 Jan 14, 2013 01:19 PM
