Apr 25, 2018, 04:53 PM
How to control electric bus by underground wire ?
Hi,
how to guide electric bus by underground wire , using metal or Hall detectors to calculate the correct drive path, direction to match overhead power lines ?
In the following video, electric trolleybus model is driven by overhead line and drive direction path follows overhead power lines
Eheim Trolleybus (2 min 13 sec)
Since my kids car turned trolleybus is much heavier, I cannot use overhead power lines as a guide to drive path, so I need to bury
another wire in the ground and use metal detectors or Hall detectors to follow the correct track to draw energy from overhead lines.
Any idea ?
Discussion How to wiring of PPM, S-BUS,i-BUS receiver? congcon97 Multirotor Drone Electronics 6 Aug 06, 2019 02:08 PM
Question JP Retract Controller V2 , How to wire it up ? gva1956 Flight Accessories 2 Feb 03, 2018 01:10 PM
Discussion replace 2 wire servo by 3 wire servo .. how abdahorn Rock Crawlers 1 Sep 06, 2017 12:00 PM
Help! How to hook up a SuperN Simonk 12A 2-3S Mini Electric Speed Controller ESC for plane gritty Multirotor Drone Electronics 0 Apr 22, 2017 07:31 PM
Discussion How to wire an electric scooter Joecool73 Robotics 1 Sep 16, 2016 05:12 PM
