This thread is privately moderated by HD Hucker, who may elect to delete unwanted replies.
Apr 23, 2018, 11:13 AM
Trader Rating: 841
$125.00 USD
Buyer pays shipping
Sold
Hitec HS-7956SHR Rudder Servo like New!
Like new! Setup and never flown. Perfect shape! Please pm me. Thanks specs:
Features:
- All-in-one Rudder Tray on Metal Top Case
- Large size ball bearing for 3.5 inch Rudder horn
- Metal turnbuckle pull-pull wire tensioner
- 2 cell Li-Po compatible (6 cell NiMH)
- G2 Digital Amplifier w/ MOSFET drive
- Durable steel gears with dual ball bearing
- Ultra hardness gear shaft with 3 axial metal
- Heat sink for motor
- Water and dust resistant
Dimensions1.57” x 0.79” x 1.45” (40 x 20 x 37mm)Product Weight2.40oz (68g)Output Shaft Style24 tooth (C1) splineVoltage Range6.0V - 7.4VNo-Load Speed (6.0V)0.15sec/60°No-Load Speed (7.4V)0.12sec/60°Stall Torque (6.0V)277.74 oz/in. (20 kg.cm)Stall Torque (7.4V)340.24 oz/in. (24.5 kg.cm)Max PWM Signal Range (Standard)750-2250μsecTravel per µs (out of box).067°/μsecTravel per µs (reprogrammed normal res).133°/μsecTravel per µs (reprogrammed high res).060°/μsecMax Travel (out of box)101°Max Travel (reprogrammed normal res)199.5°Max Travel (reprogrammed high res)90°Pulse Amplitude3-5VOperating Temperature-20°C to +60°CContinuous Rotation ModifiableNoDirection w/ Increasing PWM SignalClockwiseDeadband Width2µsMotor TypeCorelessFeedback Style5KΩ PotentiometerOutput Shaft SupportDual Ball BearingsGear TypeStraight Cut SpurGear MaterialSteelWire Length11.81" (300mm)Wire Gauge22AWG
Sold HS-7956SHR Hitec rudder servo BlinkguY Aircraft - General - Radio Equipment (FS/W) 1 Sep 10, 2017 11:57 AM
Sold HITEC HS-7956SHR Rudder Tray Servo NIB eagle650 Aircraft - General - Radio Equipment (FS/W) 1 Jul 09, 2017 01:15 PM
Sold Hitec HS-7956SHR Rudder Tray Servo Brand New SaltyPilot Aircraft - General - Radio Equipment (FS/W) 1 Mar 16, 2017 05:05 PM
Sold Hitec HS-7956SHR Digital Rudder Servo mer1051 Aircraft - General - Radio Equipment (FS/W) 1 Oct 17, 2016 10:18 PM
New Product Hitec HS-7956SHR Rudder Tray Servo in stock! ServoCity ServoCity.com 0 Feb 22, 2013 05:30 PM
