Apr 20, 2018, 01:54 PM
DDG 51's Avatar
Build Log
Smit Japan
Long time I have on shelf fiberglass hull for this tug with installed mechanical parts, today I started new rotation at work, so I starting work on superstructure for this tug too. Plan is, I will have in 2 weeks superstructure done in 5 pieces, just because transportation on board in aircraft on back flight home. Today I had some cutting day and little glueing ;-)
Tug is in scale 1:32, lenght 86 cm. Material will be fiberglass and some little of plast.
Apr 20, 2018, 02:32 PM
What material are you using for the superstructure? Looks like G-10, but hard to tell.
Apr 20, 2018, 07:01 PM
DDG 51's Avatar
Fiberglass
Apr 21, 2018, 08:19 AM
Sylvain's Avatar
Nice work as ususal!
Originally Posted by DDG 51
Fiberglass
And where is that material available from?
Apr 21, 2018, 10:34 AM
DDG 51's Avatar
I have local company wthat is selling some electrical insulation materials, they have fiberglass sheets in size 2x1 meter in different thickness. It is pretty much cheap but excellent material for ship building. Thickness is starting on 0,25 mm uto to seome 5 cm. This superstructure part is 0,75 mm
Today I finished front section of superstructure.
Apr 21, 2018, 12:59 PM
In the states, it is readily available online, although local shops may carry it as well. Not sure about Canada though.
http://www.eplastics.com/Plastic/G9-...hoCX5oQAvD_BwE
This looks like really good stuff to work with for structures, may have to give it a try.
Apr 21, 2018, 04:05 PM
DDG 51's Avatar
For my models I am using this material years and never more anything else. I am cutting this by sheet metal scissors, using regular crazy glue, nothimg special.Surface needs little sanding before glueing and primer. Just for case,if on surface is some separator from manufacturing process...
Apr 21, 2018, 04:49 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
It really is great stuff to work with-I make my own. On a flat surface I lay down parchment paper then a coat of polyester resin upon which a layer of fiberglass cloth-more resin -more cloth(2-3 layers) then cover with parchment paper. Then squeegee out resin with a credit card...makes a surprisingly uniform sheet to work with...built my gato sub by that method.
Apr 21, 2018, 05:20 PM
Sylvain's Avatar
Ok, thanks for the link Mitch.
Apr 25, 2018, 10:57 AM
DDG 51's Avatar
today is again model building day, superstructure is almost done. Doors, covers, winches... will be next
Apr 25, 2018, 11:23 AM
Bob Gaito's Avatar
Beautiful workmanship ..looks like a lot of cut and try. I don't know if I could get that result. I would have had to photo copy the prints and glue them to the fiberglass with a water soluble glue (Elmers) then cut out and assemble...then remove glued prints after with water...
Apr 25, 2018, 11:47 AM
Sylvain's Avatar
Nice and fast work!
Apr 25, 2018, 07:25 PM
DDG 51's Avatar
Yes, it was pretty fast job, and yes, it was cutting and trying. But I like job as this. Mostly when I am at work ;-)
Apr 29, 2018, 08:31 PM
Bob, what weight cloth do you use for your lamination ?
JimS
Question Smit Rotterdam electrical/dual motors stiks Scale Boats 5 Apr 05, 2018 04:31 AM
Discussion Smit Nederland power dash8man Scale Boats 2 Mar 08, 2018 07:41 PM
Discussion May God bless Japan and all people on Japan twn Chen Japan 1 Mar 26, 2011 06:08 PM
Build Log Smit Japan jenno Scale Boats 18 Dec 21, 2009 06:19 PM
