Power System 12S~Phoenix Edge 120HV & TACON Bigfoot-160-245Kv motor - RC Groups
This thread is privately moderated by stickjocky, who may elect to delete unwanted replies.
Apr 16, 2018, 02:35 PM
Trader Rating: 3
$175.00 USD
Split shipping costs
Sold
This setup was never used because I moved on to other projects.
Castle Creations Phoenix Edge 120HV 50V 120-Amp ESC
Phoenix Edge HV 120 Specs:
Applications:
Helis: 550, 600, or 700 Class
Fixed wing: Giant scale
Technical Specs:
Input voltage: MIN: 3S LiPo MAX: 12S LiPo
Max continuous amperage at full throttle: 120 amps*
Size and Weight:
Width: 2.0" (50.8mm)
Length: 3.3" (83.6mm)
Height: 0.9" (23.2mm)
Weight w/wires: 5.2 oz (148.8g)
Weight w/o wires: 2.4 oz (69.4g)
Model #: 96M608-Bigfoot-160-245Kv
Weight: 645g
Input Watts: 2700W
Outside Diameter 62.8mm
Lenght 64mm
No. of cells (lipo) 14
Max Efficiency 93%
Max Efficiency current 75
No Load Current(A) 7.4V 1.9
Internal Resistance: .0.03 ohms
Shaft Diameter 8 mm
Shaft Length 20 mm
KV (RPM/Volt) 245KV
Turns (for cars) Poles 8
Max Voltage 58
Wire Size 0.25
Bullet Connectors Yes
Bullet Connectors Size 4.0 mm
Apr 16, 2018, 06:25 PM
Trader Rating: 2
Would you take 150 for it
Apr 16, 2018, 07:03 PM
Trader Rating: 3
sent PM
Apr 16, 2018, 07:42 PM
Trader Rating: 2
Paypal ok
Sold Tacon Bigfoot 160-245kv, Hobbywing 11a HV OPTO ESC Karpinski4137 Aircraft - Electric - Power Systems (FS/W) 0 Sep 20, 2017 04:23 PM
Found Tacon Monster Bigfoot 160 245kv Hoverup Aircraft - Electric - Power Systems (FS/W) 0 Oct 21, 2016 08:59 PM
Wanted Tacon bigfoot 160 245kv Eric Paul Aircraft - Electric - Power Systems (FS/W) 2 Aug 12, 2016 07:03 PM
Sold Tacon BigFoot 160 245kv jw357_23043 Aircraft - Electric - Power Systems (FS/W) 2 Jun 19, 2013 05:58 PM
Sold Tacon BIGFOOT 160 245kv Rudderman98 Aircraft - Electric - Power Systems (FS/W) 2 Jun 19, 2012 04:49 PM
