CiottiFPV - 88mm - 2s - 2" - X2 Elf build - RC Groups
This thread is privately moderated by Ciotti, who may elect to delete unwanted replies.
Apr 16, 2018, 10:39 AM
Trader Rating: 0
$180.00 USD
Seller Pays Shipping
For Sale
All the details... https://rotorbuilds.com/build/11341
This 88mm X2 Elf was the platform where I found the swet spot for 2" props on 2s, this is about as small as you can build a rig that will swing 2" props but still carry a battery big enough for 3+ minute run times with motors that make good power.
This was also one of the more challenging builds I've done, I used MuteFPV's build guide on Youtube as a starting point and then improved on it over time. The biggest improvement was to put the VTX on the bottom of the top plate so that it's fully protected.
As I dialed the build in it evolved into a light weight (56.3 gram) high performance setup that sacrifices a bit of durability. It still takes a crash really well, but if you're looking for a basher rig this is not setup for that right now.
As you can see this comes with a ton of different props so that you can see which ones you like best but my favorites are the Gemfan 2035's that are currently installed. It also comes with six 2s 600mAh BetaFPV branded GnB batteries that have only been cycled around 20 times and absolutely rip.
The F4 flight controller is fully soft mounted and the tune is locked in really nice
X2 ELF 88mm Micro Brushless FPV Racing Frame
Eachine Minicube F4 Flight Controller
Eachine Minicube 10A BLHeli_S 16.5 4 In 1 2-3S ESC
Goolsky 4pcs GoolRC 1104 8700KV 2S Brushless Motors
Crazepony FPV Camera 1.2G 1000TVL 1/4 CMOS 2.8mm Lens FOV170
Eachine ATX03 Mini 5.8G 72CH 0/25mW/50mw/200mW Switchable FPV Transmitter w/ Audio
Frsky XM Plus Mini Full Range Receiver
6x BETAFPV (rebranded GnB) 600mAh 2S Lipo Battery 7.4V 80/160C JST
FOR SALE: CiottiFPV 88mm 2" X2 Elf (2 min 11 sec)
Apr 16, 2018, 09:45 PM
Trader Rating: 0
Farewell 2" 2s X2 Elf (1 min 54 sec)
Apr 20, 2018, 03:11 PM
Trader Rating: 0
Still available
Sold BNF 88mm 1103 2s f4 build (frsky) + 5x 450mah 2s batts ryancx Aircraft - Electric - Multirotor (FS/W) 12 Jan 07, 2018 07:22 PM
Sold X2 TLE 88mm 2s brushless kywmild Aircraft - Electric - Multirotor (FS/W) 0 Nov 02, 2017 10:48 PM
Sold X2 TLE 88mm 2s brushless kywmild Aircraft - Electric - Multirotor (FS/W) 0 Oct 14, 2017 12:08 PM
Sold X2 TLE 88mm 2s brushless for sale! kywmild Aircraft - Electric - Multirotor (FS/W) 3 Sep 30, 2017 11:56 AM
Sold X2 TLE 88mm 2s brushless for sale! kywmild Aircraft - Electric - Multirotor (FS/W) 0 Sep 25, 2017 08:53 PM
