This thread is privately moderated by Jetpop, who may elect to delete unwanted replies.
Apr 16, 2018, 09:13 AM
Trader Rating: 0
$225.00 USD
Buyer pays shipping
For Sale
Power Box I Gyro SRS New
Price
$225
Condition
New in Box
Why Selling:I have PB Royal SRS
Item Description:
Power Box IGyro SRS, new
C/W GPS
originally cost me $549 from Chief
the servo info is on the back side of the Igyro, so I placed a port sticker on the front lower left, I removed the sticker, the corner is slightly faded from the sticker, the Igyo is new and never installed
Reduced to$225 plus Shipping ($10), Paypal add 3.5%
9058570062
Rcpete
Specs
PowerBox iGyro SRS
The PowerBox iGyro(TM) SRS is a completely new type of gyro system intended for fixed-wing model aircraft. At the development stage our constant aim was to combine maximum versatility with simplicity of operation. The system incorporates a regulatory algorithm specifically developed for fixed-wing models which causes hardly any alteration in the model's familiar flying characteristics; at the same time the aeroplane flies much more smoothly and accurately and is less sensitive to unwanted weather-induced or aerodynamic influences. The need for mixers, such as elevator to rudder or flaps, is eliminated entirely. The iGyro(TM) exploits the latest servo bus technology to minimise the extremely complex wiring arrangements necessitated by previous gyro systems.
The ability to assign any channel to the gain adjusters makes it possible to set up the desired gyro effect accurately in just one short flight. Independent adjustment of each of the five outputs is possible, enabling the modeller to set up gyro gain and direction of effect precisely. The separate GPS sensor provides a means of obtaining a constant gyro effect over the model's full speed range effectively eliminating the problem of over-compensation leading to oscillation in high-speed flight. In version 16 and later the software includes a menu-based setup assistant which makes it possible to complete all the settings in just a few minutes.
The PowerBox iGyro SRS SENSOR ONLY is also available seperately (Standard and Futaba S-BUS II) - Please click here
Features:
Extremely accurate triple-axis MEMS sensor
Special regulatory algorithm designed for fixed-wing model aircraft
Menu-based setup assistant
Three-stage flight phase switching
Three axes distributed to five servos, each adjustable independently
GPS-regulated gyro gain
Integral delta mixer
Can be installed in any attitude
Graphic OLED screen with 128 x 64 pixels
Ultra-simple menu-controlled programming method using the SensorSwitch
SRS technology for use with various bus systems: Futaba S-Bus, Spektrum DSM2 / DSMX, JR DMSS, HoTT, M-Link and Jeti
Unrestricted channel assignment (channel mapping)
Digital output can be passed on to an SRS PowerBox system
16-bit processor for fast, high-resolution signal processing
Settings can be stored on a PC and reloaded at any time
Updateable with PowerBox Systems USB Interface connectors
Robust aluminium case
Technical Data:
Operating voltage 4.0V - 9.0V
Current drain Power-on state 51mA
Current drain, GPS 60mA
Maximum load current 10A
Signal input serial
Supported RC systems Futaba, Spektrum, JR, Jeti, Graupner, Multiplex
Receiver redundancy SRS
Servo sockets 5
Servo signal resolution 0,5s
Gyro regulation Heading- and Normalmode
Gyro sensor type MEMS
Number of sensor axes 3
Screen OLED 128 x 64 pixels, graphic
Dimensions 52 x 35 x 14 mm
Weight 50g, incl. GPS Sensor
Temperature range -30C to +75C
Sold Power Box Competition SRS Jetmanbob Aircraft - Fuel - Jets (FS/W) 0 Nov 02, 2017 09:51 AM
Sold Used Power Box igyro srs gps phangi65 Aircraft - General - Radio Equipment (FS/W) 1 Oct 31, 2017 09:04 AM
Sold Power Box Competition SRS WILEYEBROWN Aircraft - General - Radio Equipment (FS/W) 2 Oct 09, 2017 10:03 AM
Sold Power Box Competition SRS and extras aerosheldon Aircraft - General - Radio Equipment (FS/W) 1 Oct 03, 2016 09:12 AM
For Sale Power box champion rrs with switch and optional gyro srs indydrt33 Aircraft - Electric - Power Systems (FS/W) 0 Mar 12, 2016 08:00 PM
