Apr 16, 2018, 09:00 AM
SilbernerSurfer's Avatar
Throttle range?
May someone tell me how to programm throttle range with this 25amp ESC, please?
Apr 16, 2018, 11:38 AM
User Registered
RustyUs's Avatar
Be sure to stop by the manufacturer's website to download the ESC manual. It looks like one of them GoolRC ESCs.
Apr 16, 2018, 11:55 AM
I cant find a manual with google! Can someone post a link please?
Apr 16, 2018, 02:19 PM
User Registered
RustyUs's Avatar
From what I can tell, your ESC has no Setup button to calibrate throttle. I believe your ESC just looks for the Neutral signal, and all is good (should be). I've had an ESC operate in this fashion, but it was many, many years ago. It came with a RTR RC, and I quickly got rid of it. Maybe have a look at Hobbwing's QUICRUN 16BL30 ESC.
This PDF manual is for the RaceStar version of your 25A ESC...
Apr 16, 2018, 02:37 PM
Igottabeme's Avatar
You can't program the throttle it does it internally by itself. No button on the esc to do anything. Only five program options with the program card. You need the program card to change anything. They are very basic escs cheap but get the job done. Racerstar, Goolrc and other brands that look the same but have different colored heatsinks use the same program card. https://www.banggood.com/Racerstar-L...r_warehouse=CN
Apr 17, 2018, 11:05 AM
Did I make the A Main?
bill_delong's Avatar
I have seen some brands of ESC that need to be calibrated every time the unit is turned on. Sometimes you can adjust the throttle range by limiting the EPA on the throttle control through the Tx.
Help! Motor jumpy throttle at mid throttle range Pmworlds Multirotor Drone Electronics 3 Aug 08, 2017 11:23 AM
Discussion Throttle Ranges DX6 Radio stemo99 Power Systems 9 Dec 29, 2015 07:07 AM
Discussion Tutnigy 9X throttle range Gico Radios 2 Nov 10, 2015 01:51 PM
Discussion Throttle range change crobar Power Systems 9 Nov 03, 2015 04:06 PM
Discussion Throttle range check mensite Electric Plane Talk 3 Sep 28, 2015 04:43 PM
