Apr 15, 2018, 05:02 AM
I've used MKS servos too in my F3X planes, some servos are failed down from unknow reason (flaps, ailerons, elevator)
My personal experience : JR or Futaba servos are more trusted servos.
Apr 15, 2018, 04:00 PM
F3F addict
ThorstenFolkers's Avatar
I´m using MKS servos since many years and Í have had one 6125 mini that burned down.
And a 6625HV with a stripped gear after a heavy crash.
I put the healthy gearset from the 6125 into the 6625 and it works fine again.
Out of 16 MKS Servos in total only one lost over the years ... I guess I have been lucky with MKS in the past.
For this season I will try KST servos again because of the price difference.
Will see how that turns out!
(btw, I'm not sponsored by anyone)
Apr 16, 2018, 05:24 AM
Biest's Avatar
I have seen so many Pilots loosing there Planes (or not able to Launch, because the Transmitter beeped for RX-Low-voltage) because of an issue with there MKS 6125-Servos, that I never tried them while the LowVolt times.
While we changed to HighVolt i had 0 Fails on around 32 pcs. JR (179/189).
As they where stronger i bought 8 pcs. MKS 6625. One of them stopped working after around 8 hours Airtime. The Replace (German distributor) cost me another 90 €.
MKS is again history for me. Its not worth the Price.
Actuilly i assemble KST. Till the last 2 Years with 20 pcs. no issues.
Tobias Reik
(not sponsored by anyone)
P.S.: I don't think MKS cares about this Tread. They make there money not with the accessoiries of our toys. We are only a "nice to have".
Apr 16, 2018, 08:36 PM
MKSservosUSA.com's Avatar
MKSservosUSA.com would like to let you know that we do care about our customers and have worked very hard to look after our customers in our territory.
This “Vendor Forum” area was created by RC Groups and the moderators thought it would be best to have one area for anything MKS. (Notice that this forum represents many different manufacturers.)
I hope you also see that we have kept this thread unedited, all we ask is to keep it clean and please, no need for name calling.
We have spoken with the team at Mark Star, the owners of MKS, who also care about their customers and are working hard to create a stronger gear that is better suited for the demands that F3F brings.
Once any update is available, we will share these details here.
I am sorry to hear of the lack of after-sales support in some countries and have shared your disappointment directly with Mark Star.
If you have any constructive questions, please feel free to post here or PM me and we will work thru them.
Regards,
MKSservosUSA.com
Apr 17, 2018, 02:37 PM
F3B
satinet's Avatar
When was this sub forum created and was it someone from mks that asked the rcgroups mods to move the post? Your post implies that rcgroups decided to created the forum and move the thread off their own back.
It would have been nicer for the thread to stay on f3x where people would actually have seen it. As every servo mentioned was a glider servo.
Apr 22, 2018, 09:21 PM
F3B
satinet's Avatar
When is the 6130 thread getting moved to this 'anything mks' sub forum?
May 08, 2018, 09:05 PM
I've used 6100's, 6125's 6125 mini's and 6130's in various F3J sailplanes. All have worked perfectly. I'm extremely satisfied with MKS servos !
Jun 23, 2018, 09:29 AM
KC6ZZS
Ben Clerx's Avatar
Yes, I'm a sponsored MKS pilot. If I have an issue with something that I believe is a problem with the product, I expect MKS to fix it in their next revision to that particular servo. And they do. If I keep flying their servos, it means I'm pretty happy with their product. There are other good brands like JR and Futaba, and they are all tight and center well. But I like the way MKS addresses sailplane wing mounting options.
Issues? Not really. I had one that was DOA and it was promptly replaced. Had another one burn up during install, but that was my fault when I hooked it up with reversed polarity (how dumb was that?). Replaced one stripped gear in the last 3 years of flying MKS. Sorry, thats to be expected in F3J where you dive a $3K plane into the dirt on every "landing". I don't always get the flaps up every time and it puts a great load on the gear train. And thats just the initial impact shock. Dragging extended flaps during a flat landing is even worse. I have new planes arriving soon and they will be outfitted with MKS servos (6110's and 6130's). Sponsorship is irrelevant since I still pay for them and I can use any brand of servo that I want (multiple sponsorships).
If anyone has repetitive problems with any servo, let the MKS distributor know about it. But also take a hard look at what you're doing with your servos. Crashes and hard landings (which would be classified as a crash by spectators watching an F3J contest) will strip gears. 20 years ago it was common to replace gears at a contest. Now it is so rare, I probably don't remember how to do it
Ben Clerx
Feb 10, 2019, 05:52 AM
Mks hbl 380
I use 8 MKS 380 on my demonstrator 120 cc...
1 burn out on flight
1 when i put my finger on the surface, the servo can't move and get very hot.
A friend mine was flying his EF extra 300 v1 and 8 MKS 380, and the servo just freeze on flight...
These airplanes had 50 flights max.
Too expensive servo and too much problem.
I'm thinking to buy futaba 9177 HV and never go back to MKS.
i tryed to send email to MKS, but no response at all.
GL with MKS servos.
Feb 11, 2019, 05:02 AM
F3B
satinet's Avatar
Ben Clerx
Bit of an issue in creating a special sub forum to hide reasonable discussion on the quality of the product.
I'm surprised gliding OZ hasn't deleted all this yet - he seems that kind of guy.
May 28, 2019, 02:16 PM
Hi,
I'm using MKS HV6100 for the V-Tail of my Shinto.
Last weekend, one of them failed during the fly.
The servo remain blocked. I've checked the gears and haven't seen any damages.
I removed the gears, and saw that the motor remain blocked.
Anyone had the same issue?
Can you please let me know if there is something wrong with the blue wire on this picture.
Thanks for your help.
Best regards,
Jun 25, 2019, 11:42 AM
DS Junkie
Screamin' Eagle's Avatar
I've hesitated for a long while in posting regarding my issues and experiences with MKS servos, but the frustration has gotten to the point where I feel compelled to post. By way of background, I have used just about every sailplane servo on the market in building somewhere between 50-75 sailplanes over the years, for myself and others. I've lost track of exactly how many, but suffice it to say I build constantly, especially over the past 5 years.
I have been using MKS for all the high-end builds on fast Dynamic Soaring airplanes, where no corners are cut and no expense is spared. Primarily, these have been the MKS 6130 servos. Thus far, I have had at least 5-6 failures of these servos. 3 have been DOA as soon as they are powered up, or shortly thereafter on the bench. The others have failed after being flown, some for a long time. 2 of the 6130s developed very erratic centering in the elevators of DS planes. Had this not been discovered during routine pre-flight checks, it would have resulted in total destruction of the airframes.
A third developed an unreasonable amount of slop after about 25 flights and had to be replaced. I should mention that in these planes, removing glued-in elevator servos is considered surgery. To save damage to the airframes, I had to dremel out the servos.
All of these servos were run on 2S Li-Ion packs, no regulator.
The last straw came over the weekend. I just outfitted a brand new 3.5M Explorer with MKS 6110 servos. Through extensive bench testing and set up, everything was working well. Upon arriving at the field for the maiden flight, one of the 6110 servos in the ailerons was buzzing non-stop, despite having no friction anywhere on the linkage. At the field, I removed the servo from the frame and took off the servo arm. Still buzzing, non-stop. No glue anywhere on it, no visible reason for it to be binding. Predictably, it burned itself up within minutes after a very short flight. Luckily it was mounted in a third bearing support frame and is easy to replace.
Now, it is possible that I am somehow doing something to cause all these failures. But the only servo that has caused me anywhere near as much trouble has been the Air 94761z, and that is only after they have been used and abused.
So after spending several thousand dollars on MKS servos in total to outfit my DS planes, and then spending about $400 more to replace all the dead and malfunctioning servos, I am done. No more MKS for me. Yes, they perform very well when they perform, but the QC is not there and frankly, there are much better and more reliable products on the market that don't cost nearly as much. If there is a bright side, it's that these servos have not cost me an airplane -- yet -- but I know of another person who had a 6130 failure on the tail of his airplane and crashed it due to servo failure, which was confirmed in the post-mortem.
RC Soaring is a very small community and I don't want to ruffle feathers, but frankly these experiences have been extremely expensive, not to mention frustrating and time-consuming. When building for others, I have basically had to absorb the cost of defective servos because I can't possibly pass that along to the buyer.
My MKS distributor has graciously agreed to replace my 6110. Thankfully the plane was not in the air during the failure. Three of my dead 6130s (the one that hadn't yet been installed) have been sent back to MKS for replacement. I am hopeful that MKS will do the right thing and send replacements.
Jun 25, 2019, 05:20 PM
I've been using MKS 6130's, 6100's, 6125's 6100HV's and have never had a problem. I've used them in seven or eight F3J planes with zero problems. The oldest of the lot still center perfectly and I have been using two cell Li-ions airborne packs without voltage regulators.
Aug 05, 2019, 01:37 PM
DS Junkie
Sure doesn't seem like MKS pays any attention to this thread. By the way, I've received no response from MKS to the busted servos I sent in almost 6 weeks ago.
Aug 05, 2019, 06:16 PM
This is your brain on heli's
rhodesengr's Avatar
That is probably true but I have always had great CS from MKS emailing with them direct.
Discussion What has been your experience? Hellysmack Off-road Cars 12 Jun 30, 2017 06:20 PM
Discussion 3DR Customer Service- Since Solo Price Drop- What's your experience? smocksam Multirotor Drone Talk 13 Nov 06, 2016 07:02 PM
Discussion What is your favourite experience with a heli? felixthemaster Electric Heli Talk 15 Jul 10, 2016 02:38 PM
Discussion What are your experiences with syma or cheerson quadcopters? antboy6969 Multirotor Drone Electronics 0 May 27, 2016 09:20 PM
Question RC club flying off a GA airport: what is your experience ululi1970 Model Aircraft & Drone Advocacy 5 Apr 06, 2016 04:15 PM
