Apr 08, 2018, 09:28 PM
Compact Hang Plane by Propeller Hook Storage Method
Garage storage is not an option for me and my planes were "interfering" with our vacuum cleaner. So I built the rack which I call My Airport Hanger (pun here). The rack is 4' long and the center of the horizontal rod is 47' from the floor. Obviously this unit can be scaled up or down.
With clever spacing, it looks like 7 planes could be comfortably hung, if of the lighter weight foamy type; all of my planes are less than 2lbs AUW, and less than that of course without a battery installed. I bent the hooks so that they support the planes with the hook passing as close to the motor center line as practical, so the propeller is supported at the "propeller root" next to the hub circumference. The cable ties are used to prevent excessive slack in the wire, which droops as planes are added. They are installed to a slip fit so they can be moved along the rod to new positions as necessary. Planes can be located anywhere along the wire.
Mtls:
2 x 4s feet
1 x 4s verticals and bottom horizontal
1.25" dia horizontal rod
.0625" multistrand steel wire
prop saver collets as wire anchors located on exterior facets of 1 x 4" verticals
4 small casters (inexpensive from Harbor Freight
bent 12 guage copper electrical for hooks
angle brackets at the verical to bottom horizontal interface
tie wraps to keep the wire from excessive drooping with the weight of the planes
Please see photos
Apr 09, 2018, 12:05 AM
Very elegant. Looks like this is best for planes that are 3 pounds or less. You want to make sure the propeller doesn't get distorted over time if the plane is heavy. (The hanger should have plenty of padding).
Apr 09, 2018, 07:50 AM
scirocco's Avatar
An option that could exploit your frame but provide more options is 2 thin ropes under good strong tension separated by about 1-1.5". This allows props to be inserted between the ropes anywhere along the run then turned 90 degrees to be at right angles to the ropes. Adjusting model spacing is infinitely flexible. The shape of APC-E blades keeps the rope strands close to the spinner. Not sure how SF props would go.
Apr 09, 2018, 10:02 PM
Thanks for the comments from two previous posters. Rather than reply here, I will beef up my original post to address your comments.
Discussion My Plans Drawn for RC Plane Storage Rack Hugo Flynow Electric Plane Talk 22 Dec 22, 2015 01:30 PM
"Hanging" planes for storage JWeb Beginner Training Area (Fuel) 16 Mar 11, 2011 04:56 AM
Cool RC plane used to carry hang glider aloft. RLW The Builders Workshop 25 Jan 13, 2010 11:10 AM
Discussion What are people using to hang helis for storage ericnord Electric Heli Talk 8 Sep 19, 2006 09:10 AM
