Telemetry
Has anyone set up telemetry for rx battery voltage and RSSI .
Exactly how do you set this up, does it require you to take a laptop to the field to record the telemetry to view later? Is there any how to videos or such on telemetry? |
I have read on this forum that you can get telemetry on the tx display using Auroa 9 and EVO.
Has anyone had the same success with the Horus with battery voltage and rssi when the RFU has telemetry enabled. |
Only the A9 and EVO are supported.
The Horus, Taranis, etc. use the JR module. They use an extra (normally unused) pin to transfer telemetry data. It would be possible to modify our JR module to connect the unused pin to one of the expansion pins (which is what I did for the EVO). I will look at that at some point. |
Thanks Jim that would be great if you could get the telemetry working, at least battery voltage on rx. and rssi.
I bought a Horus but don,t trust it any more after the receiver failed, the x series cpu fail if used on planes with ignition APPARENTLY! So I use it on some planes with a XPS module but it would be good to have some telemetry. |
Thread Tools | |
Similar Threads | |||||
Discussion | Telemetry: Automatic Overheating Protection, Podcast: Telemetry....Only for Nerds? | Esprit Model | Radios | 0 | Jun 23, 2016 11:04 AM |
Discussion | Bluetooth Telemetry Bridge: APM Telemetry to Android Device | Event38 | UAV - Unmanned Aerial Vehicles | 6 | Oct 14, 2015 12:27 PM |
Discussion | APM 2.5, MinimOSD and telemetry and without telemetry | mawright | UAV - Unmanned Aerial Vehicles | 24 | Aug 17, 2015 11:52 AM |
Discussion | 3DR Telemetry vs HobbyKing FPV telemetry | nordemoniac | FPV Equipment | 2 | Mar 17, 2015 04:51 AM |
Discussion | 3DR Telemetry + EzUHF + FrSky Taranis Telemetry interference? | tomareal | Radios | 3 | Nov 13, 2014 02:10 PM |
