Cool, as long as I’m not doing anything wrong by doing is under input weight then I’m happy.
I think small trim would be fine in a moulded ship but my soft Radian Pro takes a bit more trim for it to have an effect than something more responsive |
Maybe you reversed the left and right servos?
Try reversing left and right, and see if that solves the problem.
It is not legal according to the official rules, because the system is easy to tamper with, and not certified in any way. But for training and club contests etc. it should be just fine. I have tried to make it compliant with the F5J rules.
Jesper |
What I meant was, is there a way to disable the SoarOTX motor timer when I have a CAM installed? |
Arm the motor, pull momentary to start it. Throttle up and launch. When the CAM shuts the motor down, pull the momentary again to switch from Motor to Speed mode. Upon landing, pull momentary again which stops the flight timers. Save score and start over. Seems to accomplish everything needed. |
Jasper good day. I am trying to use your program for f5j. I already have everything working! I just need to be able to set the Speed flight mode. I can not make the flaps raise the millimeters I need. The cruise is perfect! The thermal is perfect! But it does not let me set the speed. Can you tell me what I should do?
Jesper |
Jesper |
Thread Tools | |
Similar Threads | |||||
Discussion | F3K programs for OpenTX transmitters | jfrickmann | DLG Hand Launch Gliders & F3K | 2344 | Mar 03, 2024 09:28 AM |
Download | An Ardupilot frsky telemetry LUA script for the Horus X10/ X12 and Taranis X9D/E/QX7 | yaapu | Radios | 966 | Jan 17, 2024 09:02 PM |
Download | LuaPilot Telemetry Taranis Lua Script | ilihack | Radios | 56 | Sep 06, 2018 08:39 AM |
Discussion | how to get nigelsheffields lua scripts for Taranis to work. | nigelsheffield | Radios | 197 | Apr 11, 2017 08:56 AM |
Question | Taranis: changing menu structure with LUA Script? | Tr4n5p0rt3r | Radios | 4 | May 16, 2016 02:22 PM |
