HK Durafly Auto-G2 - RC Groups
Apr 06, 2018, 08:14 PM
HK Durafly Auto-G2
The new Auto-G2 with autostart is now on the workbench. I viewed all the You Tube videos and there are a few questions;
* There is no motor thrust line offset and one flyer commented that it flys hands off up to half throttle but more power than that requires holding some stick correction. Does this sound like it may need a little down and right shimming to the motor ?
* The rotor head is factory set with a level attitude, but most heads that I've seen on similar 3-blade rotors have a 2 ~ 7 degree tilt to the left (facing forward). Nothing is mentioned in the videos and it looks to take off, fly straight and level and land nice and level.
* A mod that made sense and shows to work is to cover the bottom of the blades with duck tape with the excess wrapped over the top LE. I have done this with fluorescent orange.
* Only one video commented about balancing the blades and rotor assembly; Yes, I am doing that and yes it was out of balance with significant blade differences.
* I will make the first flights with the stock plastic rotor head, but I have the better all metal head which I will install after the tests and proof of flight.
* One flyer suggests re-bending the wire landing gear to make the width a little wider to help prevent tip overs.
* Larger wheels are also recommended if the field grass is too tall.
Anybody out there who has flown the Auto-G2 ?
Apr 07, 2018, 06:45 AM
auto g2
Hi, Ive flown one, I found it quite easy to fly although it does like a bit of wind but not too much,
Apr 15, 2018, 08:16 AM
G2 pitches up
Hi;
I maidened my G2 yesterday and it pitched up to the point that full down would not level it. Is it the motor thrust line or head angle or CG ? I was using a Zippy 1300 battery and the aircraft had a slight nose down attitude when hung from the rotor mast.
May 10, 2018, 04:56 PM
Can somebody post a picture how to asembly rotor blades, becose i think that it came wrong from the box. In manual it say that asembly like first, but first is the asembled on the head and two spacers are bellow.
May 11, 2018, 10:46 AM
Here are pictures how to mout the blades:
https://www.rcgroups.com/forums/show...lug-Fly-Review
(and "some" additional information).
May 11, 2018, 11:59 AM
As i understand the front of the blade is down not up ?
May 11, 2018, 01:53 PM
Yes. It is an autogyro and not a helicopter.
https://www.rcgroups.com/forums/show...ns-and-Answers
May 11, 2018, 01:54 PM
Thank you. It come asembeled, but the blade was wrong mounted in factory.
May 15, 2018, 11:17 PM
Have been flying the Auto-G v1 for years (I think the only difference is v2 has pre rotating motor) and flies great with NO MODS apart from 35g lead on front as only run 1000mha. Everything like bigger wheels, adjusting landing gear, motor shims etc are due to other short comings....it flies great out of the box....unbalanced blades and all.
Instead of fitting blades with two screws replace one with a tooth pick.....just jamb in hole and snap off. When you tip over on take off occasionally the tooth pick will break as its the weakest point....not your blade or head etc
Article Durafly Auto-G2 Gyrocopter Plug & Fly Review Michael Heer Auto Gyros 160 Nov 12, 2017 05:45 PM
Discussion Build Video For Durafly Auto G2? Cantaloupeman Electric Plane Talk 0 Nov 11, 2017 09:28 PM
Help! Durafly Auto g2 aseembly Cantaloupeman Electric Plane Talk 2 Nov 11, 2017 05:07 PM
Help! Durafly Auto-G2 flex shaft broken and rotor balance RetepTrun Auto Gyros 9 Jun 30, 2017 01:38 AM
Yippee! Buddy Code for Durafly Auto G2 mcashatt Auto Gyros 0 Feb 07, 2016 11:08 PM
