SinoHobby Mini-Q 1/28 On-Road
Utilize all the available bodies and wheels from the Kyosho Mini-Z lineup with the carbon fiber Mini-Q 4wd 1/28th scale racer.
A Micro Racer From Hobbyking
Designed for compatibility with Kyosho Mini-Z bodies, tires, and wheels, the SinoHobby Mini-Q from Hobbyking delivers performance under $100. Featuring a carbon fiber shaft-driven 4wd chassis and drift-spec tires, the Mini-Q will drift effortlessly around the corners, or throw on a set of on-road tires and hug the turns on your kitchen floor! Here's what Hobbyking says about the SinoHobby Mini-Q:
Taking a lot of the hard work out of building an RC car this 1/28th scale Mini-Q chassis comes preassembled. All that needs to be done is to add a motor, ESC, servo, receiver and of course a battery. This gives you a wide choice of powertrain allowing it to be setup exactly how you want it. The Mini-Q Slash is designed to give people a less expensive entry point to 1/28 scale racing but without compromising on quality or performance and still able to accept many of the hop ups and bodies available for 1/28 racers.
This chassis is set up with shaft driven AWD and a carbon fiber upper and lower deck with billet cut bulkheads front and rear. It includes gear diffs front and rear which drive the wheels via chrome steel CVDs. The car also includes friction dampers with adjustable springs and adjustable toe and camber to fine tune your racing performance. All up the Mini-Q Slash has all the adjustability you would expect from a high performance racer. Plus it is compatible with a host of Mini-Q or Kyosho Mini-Z body shells wheels and tires!
Features and Specs:
  • Carbon Fiber chassis
  • Drift Tires included
  • Fully assembled frame
  • Polycarbonate body shell
  • Kyosho Mini-Z compatibility with body shells and wheels/tires
  • 1:28th scale
  • Weight: 80g (empty)
  • Wheelbase: 96mm (adjustable)
  • Front Track: 65.5mm
  • Rear Track: 66.5mm
Requires:
  • 1 x Motor (130 Class)
  • 1 x ESC
  • 1 x Servo
  • 1 x Battery
  • 1 x Ground Radio and Receiver (HobbyKing GT5, GT2B or GT2 Transmitter)
CLICK HERE for more info on the SinoHobby Mini-Q 1/28 On-Road from Hobbyking.
Apr 05, 2018, 08:53 AM
Low budget fun
Beaver_XT's Avatar
Got it ever since it came out. It is a fantastic car with build quality issues.
https://www.rcgroups.com/forums/show...y-Mini-Q-TR-Q7
Mini-Review Sinohobby Mini-Q TR-Q7 Beaver_XT Micro Cars 204 Mar 07, 2019 07:59 PM
Discussion New Sinohobby Mini Q 1/24 "DIY", <$40 darkNiGHTS Micro Cars 59 Sep 17, 2018 03:18 AM
Discussion Sinohobby Mini-Q AWD Pro TR-Q6C-W Quick Review legacygt777 Micro Cars 11 May 31, 2017 09:12 PM
Discussion mini q sinohobby servo mount question legacygt777 Micro Cars 3 May 17, 2017 05:26 PM
Discussion Sinohobby Mini-Q4 1/28 cherebaxa Micro Cars 18 Nov 20, 2016 06:20 PM
