Apr 02, 2018, 10:30 PM
FrSky-MKT - Forum Sponsor
AndreaHuang's Avatar
FrSky New Product RB-40 in pipeline
Functions
  • 18 channels: 16 PWM channels (8 channels with current sensor)+ 2 reserved channels (Each channel has overcurrent protection)
  • 2 power input (6 ~17V)
  • 2 SBEC output (Sustained Current: [email protected]~8.4V; Peak Current: 210A; Efficiency: ≥88%)
  • LCD window (Real time current, voltage, power consumption values indication )
  • 2 switches:
    - Software switch
    (Connect/Disconnect BAT1/BAT2 or BAT1&BAT2 through buttons/transmitter)
    - External switch socket
    (Connect/Disconnect the general power supply)
  • Black Box function: Record all the sensor data
  • Auto-switch of the telemetry between RX1&RX2
  • 2 SBUS (or other BUS such as F.Port) input and 1 SBUS output
  • External Data Interface: for connecting the programming & indication device (Such as FSD)
  • CNC shell
Welcome to leave your comments and advice here, FrSky appreciates your support and we will do our best to make the products perfect!
Apr 03, 2018, 04:00 AM
FJH
FJH
Looks really perfect for me. Only wish is that before release to public you manage to have it extensively tested by some users who fly big gasser planes.
Apr 03, 2018, 05:28 AM
Expected size and weight? Any information about that?
Apr 03, 2018, 01:26 PM
If this would auto servo match via a lua script calibration on the current sensing channels that would be awsome.
Apr 03, 2018, 07:40 PM
Hello madmao, the reference dimension is 140mm*90mm*20mm.
Apr 04, 2018, 12:57 AM
GVT
GVT
GVT's Avatar
Nice 👍
Apr 04, 2018, 01:22 AM
Power switch through the transmitter???? How does that work? How much does the system consume when 'off'? Sounds great, like the Jeti system.
Apr 04, 2018, 03:20 AM
Perfect!
Apr 05, 2018, 01:27 AM
Hello Andrea,
thanks for clarification. Nice for gassers or big sailplanes.
Florian
Apr 05, 2018, 03:08 PM
Can you clarify if a s6r or s8r can be used for stabilization with this or infact any of the rb products, cheers.
Apr 30, 2018, 01:32 PM
Joetrin's Avatar
It would be great if we could select the output latency rate for compatibility to old and new servos. Expert Servo's do not like 16ms or higher.
May 01, 2018, 01:32 AM
The two SBEC outputs, what are they intended to be used for?
Outputs for the servos? I don´t think so, but that would be nice.
I agree with Joetrin about the latency.
And when is this device planed to be available to the masses?
May 01, 2018, 01:34 AM
Yes servos. What else?
May 01, 2018, 09:03 AM
Of course you can use them for servos. But according to the pictures the SBEC:s are outputs, meaning you have to connect the servos (+ and -) outside this box.
Thas is, there is no regulated voltage through the normal servo connectors, and you have to have some type of breakout board.
Or am I wrong?
May 09, 2018, 02:05 PM
As there any time frame as to when this will be released?
New Product FrSky New Arrival - RB–20 AndreaHuang FrSky 690 Sep 29, 2021 05:46 PM
New Product FrSky New Arrival – Redundancy Bus – 10 (RB-10) AndreaHuang FrSky 618 Apr 20, 2021 12:37 PM
Careful! 'Islamic Refugee' With Gas Pipeline Plans Arrested In New Mexico SKYPILEIT Life, The Universe, and Politics 0 Jun 15, 2016 02:32 PM
Discussion What new FMS Warbirds are in the pipeline? Larry076 Electric Warbirds 6 Jun 13, 2011 02:49 PM
Discussion Any new Futabas in the pipelines?/Questions about 9CHPS ormandj Radios 12 Jun 20, 2006 07:00 PM
