This thread is privately moderated by UpNup, who may elect to delete unwanted replies.
Apr 02, 2018, 08:39 PM
Who are these that fly?
UpNup's Avatar
Build Log
Ford Flivver - Servos for Elevator and Rudder
The Ford Flivver 268 plans place the tail servos behind the firewall. Thanks to incredible technology, I put the elevator servo into the tail. I kept the pull-pull but moved it just behind the CG in the center.
Note that the cables cross and go thru the fuselage in pre-cut holes. The holes are rimmed by matching blue stirring straws I brought home from an American Airlines galley. Thanks to a recommendation I kept the rudder bracket and the servo arms about equal.
The tail servo was epoxied into place. I missed that the extension cable would drape down right into the elevator cables. So I pulled the cable up and into the hulled-out long silver headrest and above the cross beams. It worked like a breeze. If I were into this build it would have saved time to put the elevator rudder into place before flying in the king headrest.
The urge to finish this build is strong!
Help! Single servo flap setup for rudder elevator only DLG hog2soar Hand Launch 9 Mar 25, 2018 06:36 PM
Question Rudder Elevator Servo for Dragonfly Strong LSF226 Multi Task F3X 1 Oct 09, 2016 03:59 PM
Discussion Elevator vs Rudder servo - which one takes the most punishment? Dr.JJ Fuel Plane Talk 15 Nov 12, 2015 08:08 AM
Discussion Size of spring steel for rudder/elevator in DLG BulletMaster Hand Launch 4 Sep 15, 2015 06:56 AM
