Mar 31, 2018, 11:51 AM
ı ɐɯ uoɹɯɐן
Curtis in Texas's Avatar
Contest
The April Big Sky, Anyone can enter, Informal Soaring Contest
THE APRIL BIG SKY INTERNATIONAL
LONGEST DURATION CONTEST FOR ALL ELECTRIC AND HAND LAUNCHED GLIDERS, THERMAL SOARING, AND SLOPE SOARING -
RULES AND INFO:
Contest will run from 12:01 am April 1st to 11:59 PM April 31st Eastern US time. The contest is for ALL electric or hand launched gliders or airplanes of all sizes, all materials and all controls. The contest is intended to help motivate you to develop your thermal and slope soaring skills. The contest is open to all gliders, e-gliders and, if you like, e-airplanes too. If it glides, it qualifies.
In Thermal Duration, the contest is split into three classifications; 2 Meter and under E Gliders, Open E Gliders, and Hand Launch Gliders.
You can post as many times as you like using as many planes as you like, but only one will be counted per pilot per category regardless of what kind of plane you are flying. You can replace a shorter time with a longer time any point during the contest. You can fly as many flights as you like.
Goal - longest duration thermal and slope flights without use of the motor.
THE PLANES
* Any electric motor system or unpowered hand launch glider. (No winches or Hi-Starts).
* Any wing controls and any wing span
* Any construction
ELECTRIC GLIDER SOARING
1) From a fresh hand or ground launch you can run the motor for up to 30 seconds, then you turn the motor off and you can not restart it. Reclimbs are not permitted. If you restart the motor the flight time is no good.
2) Motor time starts as soon as you apply throttle. This is an LMR, Limited Motor Run contest with a pretty long motor run allowed so that the motor run itself does not provide much advantage to anyone. Many will choose to shut off the motor in less than 30 seconds. No credit for shorter motor runs.
3) Soaring time starts when the motor goes off. Either you time the whole flight and subtract the motor run or you use two watches, one to time the motor run and one to time the flight. How you do this is up to you.
4) You can time your own flight if you wish. You are on your honor. Time is truncated to the second. No fractions and no rounding. Read the seconds only.
5) Landing must be within 100 feet of the original launch location or the flight does not count. Landing must be on the ground/grass or pavement. Landing in a tree, bush, structure or other elevated spot that would not normally be a landing spot does not count. There are no other rules around the landing.
6) Time stops when the glider comes to a rest. So the clock keeps running if you clip a branch, or go to land and bounce back into the air. When the plane stops, time stops.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground/hand. No reclimbs permitted.
8) Report your best time of the day by posting here. You can post as many times as you like, but only the best one will count. You can fly as many days as you like to work toward your best time. The goal is to achieve personal bests in the fun atmosphere of a contest.
HAND LAUNCH SOARING
1) Soaring time starts at release of the plane.
2) You can time your own flight if you wish. You are on your honor. Time is truncated to the second. No fractions and no rounding. Read the seconds only.
5) Landing must be within 100 feet of the original launch location or the flight does not count. Landing must be hand catch or on the ground/grass or pavement. Landing in a tree, bush, structure or other elevated spot that would not normally be a landing spot does not count. There are no other rules around the landing.
7) You can launch as many times as you like but each flight has to be from a fresh launch.
SLOPE SOARING
1) From a fresh hand or ground launch you can run the motor for up to 5 seconds, if you need it to get into the lift. I would expect most slope flights will have no motor run but some sites need a boost to the lift.
2) Motor time starts as soon as you apply throttle and is subtracted from the total flight time.
5) Landing has to be within 100 feet of the original launch location or the flight does not count. Landing must be on the same level as the launch. Landing down the slope or up in the trees does not count. You must come to rest in a "normal" landing spot and be able to walk over and pick it up. I realize this can vary by slope site so you are on your honor as to whether this was a normal landing.
7) You can launch as many times as you like but each flight has to be from a fresh launch from the ground or hand. No powered reclimbs permitted. If you restart the motor the flight does not count.
8) Report your best time of the day by posting here. You can post as many times as you like, but only the best one will count. Try as many days as you like to get your best time of the month.
For either contest you report the results via post.
REPORT FORMAT
Your Name - Real or RCGroup Name - your choice
Glider/plane name and wingspan:
E Glider, Hand Launch or Slope:
Date and Time of flight:
Duration of flight:
Comments - You are welcome to report anything you like about the day, the flight. Pictures, videos, gps plots, etc are welcome but not required.
I will maintain the thread and keep the second post updated with the top 3 flight durations from each Class. Only one flight of each type will be recorded in the standings for each pilot. A new, better time will replace the previous one.
ALL-TIME CONTEST RECORDS
2 Meter and under E Glider Class
Andy Grose (dee-grose)
Glider name:Radian
Thermal or Slope: Thermal
Date and Time of flight:April 19, 2012 11:20am
Duration of flight:1:38:04 (after 30 sec motor run)
Max Altitude: 3028ft AGL
Open E Glider Class
MrE / Larry
Sailplane: Bubble Dancer
Date and Time of flight: 13 October 2013 2:30PM
Duration of flight: 1 hr 52 minutes 37 seconds
Weather: Mostly clear, +55F, light variable winds
Hand Launch Class
xStatiCa (Adam)
Glider Binary IV DLG (1.5m)
May 14th, 2015
Time 5:48pm
Duration 75:49
New Port Richey, FL
Slope Class
744Drv
Sailplane: Radian Pro 2m
Discipline: Slope
Date time of launch: 26 Nov 12:57
Place: Lookout Hill overlooking Discovery Bay, Hong Kong
Conditions: E 5-10kts
Duration: 3 hrs 2 mins
Mar 31, 2018, 11:53 AM
ı ɐɯ uoɹɯɐן
PunkerTFC
Radian Pro (2M E-glider)
April 23rd, ~12:00
Duration of flight: 32:11
Max altitude: 1302 feet AGL
Roger
Glider name:Radian
Thermal or Slope: Thermalg
Date and Time of flight: April 13,,2018 Around 1 pm
Duration of flight:21:31 (after 30 sec motor run)
Bruce Clapperton
Model: Easy Glider
Motor run 15 seconds
Time: 12 minutes 45 seconds
Clear blue sky, light winds (for once!)
At P&Darcs club for our annual inter club competition (VMAA Trophy). Near Melbourne Australia. Just snuck in a flight while they were doing the Limbo!
Open E Glider Class
AMA69405
Aether 3.7M
E Glider - Open
Apr 26 2018 - 1200 hrs CDT
1 hr 19 min 55 sec (after 29 sec motor run)
Dexter, Kansas USA
59 to 63 deg F, Wind Variable 2-5 mph
Glider/plane name and wingspan: Arthobby Castor- 2500 mm
E Glider, Hand Launch or Slope: E Glider
Date and Time of flight: 22th April 2018, 11:00-12:00
Duration of flight: 41:12 after 12 seconds motor
Curtis
Glider/plane name and wingspan: Radian XL 2.6m
E Glider, Hand Launch or Slope: E-glider
Date and Time of flight: 4/1/2018 1626hrs
Duration of flight: 6:36 min after 30 sec motor
484' AGL, Minimal lift this 1st flight, nada the next 5 attempts so I quit.
Hand Launch Class
Slope Class
Current thru #18
Apr 01, 2018, 05:25 PM
ı ɐɯ uoɹɯɐן
Curtis
Apr 06, 2018, 06:08 AM
Gary L
Open E Glider Entry
The wind died down from 18-20 mph earlier, so I went out and managed 3 launches late in the day. The first flight was my best of the 3, despite the fact that the 2nd flight looked very promising right after launch (see chart).
AMA69405
Aether 3.7M
E Glider - Open
Apr 05 2018 - 1620 hrs CST
11 min 18 sec (after 22 sec motor run)
Dexter, Kansas USA
69 deg F, Wind South 7-12 mph
With rain and snow showers predicted today and generally windy weather after that, it will most likely be several days before I get another realistic chance to fly.
Apr 09, 2018, 12:54 PM
Glider/plane name and wingspan: Multiplex Solius - 2200 mm
Date and Time of flight: 9th April 2018, 16:00-17:00
Duration of flight: 17:26 after 10 seconds motor.
I stopped at our local field on the way back home from work. A sunny day with some wind up to 4 m/s, with a lot of small and short lasting bubbles. I practiced low flying with max. 10 seconds climbs and 2-7 minutes flight times. Eventually IT came! In about 6th minute Solius reached the ceiling of my comfort zone and I flew to the other corner of the sky and started to descent - it took another 11 minutes :-) .
Happy thermaling to you, guys,
Jan
Apr 09, 2018, 06:34 PM
Gary L
Another early evening flight that paid off. We had moderately strong lift over a fairly large section... until there wasn't.
AMA69405
Aether 3.7M
E Glider - Open
Apr 09 2018 - 1645 hrs CST
21 min 30 sec (after 26 sec motor run)
Dexter, Kansas USA
53 deg F, Wind South 7-10 mph
Apr 13, 2018, 10:17 AM
3RN13
ernie b's Avatar
Well, I knew it was too good to last, one 70 day and just like that we're back in the chilly windy Spring weather pattern. Rats!
Ernie
Apr 14, 2018, 07:22 AM
rfk
rfk
Roger
Glider name:Radian
I am using a device for ALES which turns the motor off a predetermined altitude ( 200 meters) or after 30 seconds.
Apr 14, 2018, 11:10 AM
Date and Time of flight: 14th April 2018, 16:00-17:00
Duration of flight: 21:33 after 15 seconds motor (21:48 in total)
I did maybe 10 flights of about 2-5 minutes (after 7-10 s of motor run) and thought it too late for any substantial thermal. I almost decided to go home when a buzzard appeared nearby. So I flew directly to him - they are never mistaken, these birds.
Oh, sorry, Roger and AMA, but 21:48 was on my stopwatch :-)
Jan
Apr 21, 2018, 11:30 PM
2 Meter an Under
Bruce Clapperton
Model: Easy Glider
Apr 22, 2018, 01:38 PM
A beautiful Sunday, clear sky, 26 C, variable wind. I had to work several short lasting bubbles for the first 20 minutes, usually catching a new bubble at the treetop level. Then the next thermal was strong enough to get the plane to 200 m, and then the rest of the flight was easy. I could have been much longer but my neck was getting stiff and my wife called me for lunch .
Honestly, I am not sure I like these long flights. It is a fun to hunt for, and ride up on thermals, but once the plane is high enough it could become boring. Maybe, I have some screws loose .
Jan
Apr 23, 2018, 01:41 PM
Old school newb
PunkerTFC's Avatar
April 23rd, ~12:00
I actually managed a couple of 20-30 minute flights today; it seemed like the whole valley I was flying in was cycling at the same time. There was strong lift everywhere for ~20 minutes, and then sink everywhere with no lift to be found. I'd find a big climb right off launch, spend the next 20 minutes trying to keep the glider at a reasonable altitude while racing around the valley as fast as I could in the widespread lift, and then spend the last 10 minutes scratching at whatever non-sink I could find. I gave up after three hours because my eyes hurt from trying to keep the glider in sight!
Apr 25, 2018, 04:51 AM
ı ɐɯ uoɹɯɐן
Welcome Punker, I don't think I've seen you 'round before.
Sounds like a good day soaring, wish I could do half as well.
Apr 25, 2018, 04:54 AM
ı ɐɯ uoɹɯɐן
Originally Posted by Bclapperton
Do you realize that's not an electric sailplane?
Looks like fun and a sure way for me to crash.
Contest The March Big Sky, Anyone can enter, Informal Soaring Contest Curtis in Texas Electric Sailplanes 32 Apr 01, 2018 09:23 AM
Contest The November Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 46 Nov 30, 2017 09:46 AM
Contest The October Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 57 Oct 25, 2017 05:46 PM
Contest The September Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 37 Oct 01, 2017 11:58 AM
Contest The August Big Sky, Anyone can enter, Informal Contest Curtis in Texas Electric Sailplanes 57 Sep 04, 2017 12:33 PM
