Feb 08, 2020, 09:17 AM
UK 550/600 Tarot distributor
Smoggie's Avatar
reversing servos in Vstabi is not unusual, nothing to worry about. As for the tail servo. You need to set the servo centre point frequency and refresh rate. See the attached screen shot of where to do this, it is all covered in the instructions if you follow them.
If the servo is the ALZRC one that comes with the package, set the servo to the second line on the list, the line that starts 9251
Mar 01, 2020, 07:01 PM
Hey again. So im following the directions and can only get a little play out of the gyro. It actually works though. Only when i adjust the CCW to 140 will i start getting movment out of the servo but the travel is not enough. I think i need more dumbed down directions on how to set this up.
I have the linkage disconnected from the servo arm but i think id need to attach it to get the full range of motion correct .
Mar 18, 2020, 06:19 PM
any help apreciated
Mar 20, 2020, 02:10 PM
Helique's Avatar
...You need to set the servo centre point frequency and refresh rate.
Have you tried this yet? Iím using a different FBL (Bavarian Demon) but I had similar issues with the tail servo as youíre experiencing. I had to change these settings for the tail servo, via the FBL computer software.
Mar 23, 2020, 05:53 PM
So i was originally told 9254 for this servo i have which is DM1531T coreless. After changing to that setting things worked except for the tail. I must have oritginally burnt out the servo. I have since replaced the servo and followed the guide to do 9254 and things still didnt work. Lil hesitant to do 9251. Probably gonna give it a try again.
Yesterday, 11:51 AM
ticedoff
ticedoff8's Avatar
According to the ALXRC site, the servo uses 760uS (center pulse) / 333Hz (refresh)
I have no idea how "9254" relates to a servo.
Build Log ALZRC Devil 420 FAST - build log Smoggie Electric Heli Talk 1436 Mar 25, 2020 12:06 AM
Data 19t pulley verse 21t pulley ALZRC 420 xnova 890kv motor antdawg Electric Heli Talk 3 Oct 28, 2017 09:20 PM
Discussion ALZRC Devil 380 FAST.......... BUILD cruzroy Mini Helis 18 Feb 11, 2017 11:21 PM
Discussion Newbie to building needs help!! Alzrc devil 480 fast BillyWhiz Mini Helis 7 Feb 04, 2017 06:49 PM
