Another DAG But This Is A DAG 120 - Page 2 - RC Groups
Apr 18, 2018, 02:43 AM
BigTradioman's Avatar
Tulip wood is very stable. I used to have a local joiners shop make custom size front doors for 18 century cottages from Tulip Wood. Itís a smooth finish as well.
Apr 23, 2018, 03:21 AM
Apr 23, 2018, 03:37 PM
Apr 24, 2018, 06:11 AM
blades
Hi
The wood has arrived will be making the blades in the next couple of weeks. Also the standard size servos looked a little lost so I am replacing them with some quarter scale sized servos which are twice the physical size than the standard ones. Hopefully the metal gears will be somewhat meatier than the smaller ones. They will need to be as the weight and size of the blades would kill normal servos.
John
Apr 24, 2018, 01:38 PM
Apr 28, 2018, 12:05 PM
So latest bulletin. After installing the new large servos and linkages it has been decided that the mast is just too heavy at 5.5 lbs. So a redesign and rebuild is underway to try and bring the overall weight down.
May 05, 2018, 01:42 AM
Rebuilt mast saved about 1lb.
May 22, 2018, 11:42 PM
AND FOR MY NEXT TRICK....!
jodini's Avatar
Now this is worth watching!
May 23, 2018, 03:09 AM
So the latest news from the JK man cave...........we machined up 3 blades from solid Tulip Wood with the same thickness and profile as my DAG and a little under 5 foot length. The plan was to include a groove towards the leading edge to give correct cg by inserting piano wire. However with balancing and covering the 3 blades weigh in at a whopping 4 lbs. now thatís a bit scary when you think of the inertia and stored energy in those blades at flying RPM. JK is now considering building a second set using the traditional method but with a lite ply bottom skin to edge strength. Next move is to get the motor running and do some taxi trials without the blades, then with the blades to test spin up.
What could possibly go wrong.
The Best of Kenny Everett Reg Prescott Diy (3 min 52 sec)
May 23, 2018, 05:01 AM
Ricardo1500's Avatar
Tim
I used thin. Birch ply under my big blades and also glasses them in light weight cloth and Easicote...... strong light and stiff
May 23, 2018, 01:41 PM
Thatís probably the direction he will go in Rich. I think we are going to find the Tulip wood blades too heavy. Too much inertia to spin up without a howling gale or a very long runway.
May 25, 2018, 06:11 AM
I also used full length of spring steel wire in the le to get the c of g right
May 26, 2018, 02:58 AM
Yes I can see how that would be needed. Any idea how much each blade weighed?
May 29, 2018, 07:05 AM
Tim
A 1420mm blade is about 450 grams, that’s glassed, painted and with root reinforcement, ie ready to fly ( or crash!)
May 30, 2018, 01:33 AM
So near enough a 1 lb.
Discussion Another night club shooting ... but this time stopped by CCW logan5 Life, The Universe, and Politics 56 Jul 05, 2016 12:25 PM
Discussion Another Waco SRE build - but this one gets 16 cells! tim hooper Scale Kit/Scratch Built 160 Oct 07, 2012 10:37 PM
Build Log Yet another SA Stella....But this one is different! P-38J-Lightning 3D Flying 4 May 10, 2006 05:14 PM
Joke Maybe this should be in another forum...but.... AirWarriorBelgy Humor 8 Feb 20, 2006 08:07 PM
oh no, another miniflash build! (but this one is different) member73 Parkflyers 38 Aug 12, 2003 08:29 PM
