May 29, 2019, 02:14 PM
http://rcmodelflying.tk
Modelairplane80's Avatar
Here some first shot movies with my Firefly8SE 90 most are shot a 1080 60 with gyro on
still needs a little workand try some other modes
Twinstar2+Firefly 8SE 90 - Airfighterclub Gorinchem (10 min 7 sec)
Hobbyking (Milled by me) Volador Aeromusical training flight 3 (3 min 15 sec)
Twinstar 2 30-03-2019 (10 min 51 sec)
Bling Bling V3 tijdens de indoordag 10-3-2019 van Modelvliegclub MVC Woerden (6 min 10 sec)
Fourstar 40 flight 1 on 18-05-2019 Airfighterclub (11 min 18 sec)
Some of the first flights of the Fourstar40 after setup change
F3A Arcus aeromusical practice (7 min 18 sec)
Jun 01, 2019, 06:20 PM
mr1
mr1
Originally Posted by bobflyman2
On this video at minute 11:53 it looks like it has the same green lens flares like my Firefly 8S.
Does anyone know if the 90 degree lens was improved from the Firefly 8S? I can read a lot about lens improvement but when I look at 90 degree videos I cannot see it.
Jun 05, 2019, 09:46 AM
Can I use this can also as dash cam and motorcycle helmet cam ?
Besides camera of quad and rc car ?
Jun 05, 2019, 10:36 AM
bobflyman2
Yes it has loop recording, for dashcam use. And I have motorbike cam footage on my review of this camera. With vlogging, ie using the external mike.
Firefly 8SE unboxed, full version, great tests clips, using camera, wifi, microphone vlogging (37 min 3 sec)
Jun 07, 2019, 07:56 AM
Thanks Bob. Great video. Had not have the time to watch all of them but mabye u know, can I connect the cam with an eachine tx05 aio cam ?
And would it be possible to switch between front and rear camera when connected with tx05 ?
And can the 8se also transmit sound ? When using an compatible video transmitter ?
Jun 07, 2019, 10:08 AM
bobflyman2
I just looked at the FPV lead on the Firefly I'm not sure it does have audio out? You had better ask Firefly I thing. Hawkeye is the company.
Jun 16, 2019, 04:36 PM
yyvon66's Avatar
i think it's the same
Jul 16, 2019, 04:09 AM
Hi
I will describe my problem with FF8SE
My Firefly with MODx 3.0 has stopped working. After turning on the camera, power button led is lit (bottom part) and that's all. No screen reaction, front led is off and no possibility to turn off the camera. When the power led is lit, the camera gets hot like as during normal operation. To turn the camera I need to take off the battery. Connecting to ac power (with or without the battery) give the same results.
I have also taken the battery off for a longer while and wait until the camera cools down. Only one time the camera where able to turn off (for a few attempts).
I haven't doing anything special with the camera.
I've recovered with elf, put the battery back, turned on and it seemed everything was ok. But when I disconnected form the pc and tried to turn on once again, the camera stucked as before.
Recovery made once again and still the same.
I don't know, maybe there is something wrong with the battery? It is fully charged, the voltage is 4.12.
Tried with another battery. Still the same.
When turning on without cable, the button is half lit with very low brightness like the voltage is lower.
When connecting the cable, the button is lit like during charging (full brightness) for a while and then remains half lit.
The camera was disassembled for a few days. I put the battery back and it is working. One day of recording and everything was ok. At night I plugged it for charging and next day the same problem.
I think there is a problem with power supply circuitry. Maybe there is something with internal capacitor (used for keeping the date)? I think the camera is able to turn on when this capacitor is discharged.
I have disassembled the board but I cannot localize such element. Can anyone help me?
Jul 22, 2019, 02:19 AM
gimbleguy's Avatar
Originally Posted by Victor.K
We developing a less distortion lens on Firefy X
Hello,
When is the Firefly X coming out? Also will it have gyro support for 2.5K/1440p 60FPS videos?
Thank you
Jul 22, 2019, 03:34 AM
RocketMouse's Avatar
GIVE US Firefy X!!!!
It should have EIS up to 4K60fps, otherwise you can buy SJ8Pro that has it up to 4K30fps right now!!!!
Victor, just please don't forget about 90 degree lens + AV-out.
And don't make AV-out the stupidest way how SJCAM made it - needed to switch on every time after camera powered. SJCAM is really failed with that.
Jul 22, 2019, 03:51 AM
bobflyman2
Originally Posted by gimbleguy
Hello,
Thank you
I have been told by Hawkeye that plans for the Firefly X have been scrapped
Jul 22, 2019, 04:50 PM
gimbleguy's Avatar
Oh no.
thank you
New Product FIREFLY 8S - AMB_A12 + IMX117 - Gyro,Display 2'', Wi-Fi, GoPro size **Owners Thread** Marcofan76 Aerial Photography 2135 Jul 30, 2019 10:00 PM
Discussion FIREFLY 7S - NT96660 + IMX078 - Gyro,Display 2'', Wi-Fi, GoPro size **Owners Thread** Marcofan76 Aerial Photography 305 Sep 17, 2018 09:10 AM
New Product FIREFLY 8 Lite - NTK-96660 + IMX117 - Gyro, 2'', Wi-Fi, GoPro size *Owners Thread* Marcofan76 Aerial Photography 35 May 13, 2018 01:28 AM
New Product A 90 degrees FIREFLY 7S **Owners Thread** Victor.K Aerial Photography 36 May 20, 2017 10:55 PM
Mini-Review HawkEye Firefly 6S 4k (2160p) vs Firefly 5S 1080p Comparison Sunny_1 Aerial Photography 2 Nov 09, 2015 05:29 PM
