This thread is privately moderated by aero nishi, who may elect to delete unwanted replies.
Mar 27, 2018, 05:08 AM
RC Factory F-22 Raptor Twin Motor Thrust Vector Modification
Specifications:
Motors: DYS 1306-2300KV x 2
Props:RACEKRAFT 5045 5" TRI-BLADE PROPELLER - CLEAR x 2
FC: OMNIBUS F4 Nano v3 with LC filter (Betaflight)
ESCs: WAVE 4in1 4x18A ESC(BLHELIS)
RX:FM800 Pro 2.4G 8CH Receiver
Battery: Tattu 450mAh 14.8V 75C 4S1P (outdoor)
Tahmazo 360mAh 11.1V LP3S1P360RE (indoor)
RC Factory F-22 Raptor Twin Motor Modification (1 min 10 sec)
Nov 19, 2018, 11:59 PM
LUFTGUCKER
lotsasteam's Avatar
Thanks aero nishi!
One more question: Can i use the FC Omnibus and FM800PRO RX with my DX9??
Nov 20, 2018, 03:42 AM
Originally Posted by lotsasteam
Thanks aero nishi!
FM800PRO RX is a reciever for Futaba transmitter. You can use DSMX Reciever. The FC has pads to connect DSMX RX.
Jan 08, 2019, 02:01 AM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
Awesome! I just finished my f22.... so tempted!
Jan 15, 2019, 08:54 PM
LUFTGUCKER
lotsasteam's Avatar
One more questiono I have to program the flightcontroller, I have no glue how to do that?
Jan 16, 2019, 06:08 AM
you can use betaflight configurator to flash firmware on your controller.
Nov 05, 2019, 10:09 AM
David Kyjovsky's Avatar
Dear AeroNishi,
can you show how exactly you have setup your FC? Did you use any template?
thank you
David
Nov 05, 2019, 10:16 PM
Hi David,
I used flying wing templete with differential thrust setting in betaflight. In inverted flight, it is still experimental, but I used 3D mode, bidirectional ESC setting and slightly modified betaflight source code.
Nov 06, 2019, 11:01 AM
Thank you Nishi, I am going to start experimenting with this and probably we will release EPP jet with exactly this way of propulsion. Thinking about JAS Gripen.
Nov 06, 2019, 11:03 AM
Originally Posted by aero nishi
... slightly modified betaflight source code.
in what way? would you not be happy with non-modified BF source code for this purpose?
Nov 06, 2019, 04:53 PM
To stabilize the aircraft in inverted hovering, it is necessary to reverse both rudder and elevator. When reversing motors in betaflight 3D mode, rudder will be reversed but elevator won't. That's why I modified the code. Since Betaflight is an open source software, one can access the source code.
https://github.com/betaflight/betaflight
Nov 06, 2019, 08:17 PM
David,
In normal flight, non-modified BF or iNav is just fine for the purpose. I am looking forward to your EPP jet!
Nov 07, 2019, 08:38 AM
Have you any video of changing the thrust direction during flight?
Nov 07, 2019, 10:14 AM
Sorry but I don't have such videos.
Nov 07, 2019, 10:47 AM
is it possible to transition in flight with your systems?
Cool F-22 Raptor Twin 70mm Thrust Vector EDF coming to Banana Hobby! Banana Hobby Foamy EDFs 1707 May 01, 2019 07:08 AM
Mini-HowTo FIY F-22 Raptor EDF Thrust Vectoring Modification bwoollia Foamy EDFs 0 May 17, 2010 09:12 PM
Discussion F-22 Raptor thrust vectoring scratch built twin ducted fan jet MikeysRC Foamies (Scratchbuilt) 2 Aug 05, 2009 11:29 AM
