Mar 26, 2018, 04:45 AM
OcCre S3/6 BR 18 Bavarian Dream
Hi, I'm building an OcCre locomotive BR 18 in 1:32 scale G gauge 45mm
the train is long 720mm
www.occre.com
www.occremania.com
The kit can be made dynamic or static, I have put inside a smoke unit, lights motor unit and a rc controlled system 3ch
really it not need an rc controller, I use it 1ch only , if I want I can give energy by rail (I have not) or put a servo tester to run and stop the speed controller from a leverage, at the moment rc solution is the most simple.
it have a 4 switch panel to power on all units
If you like I will show progress from start, I can describe the kit, model is still not finish.
I have to build a wooden rail.. or metal if I find something, still I have no idea about it.
Mar 28, 2018, 03:58 AM
I modified the tender, the smoke unit went into the boiler.
Hard work at this stage of assembly.
This was necessary because the distance greatly limited the flow of smoke.
I will put a short video explaining the difference between before and after.
this way is easier to open for maintenance and give much higher quantity of smoke
Mar 28, 2018, 04:00 AM
this is smoke now..
(0 min 20 sec)
and this was the smoke test before with heng long unit at 40cm distance inside tender
(0 min 14 sec)
Apr 02, 2018, 07:29 AM
two running test
(0 min 17 sec)
(0 min 27 sec)
Apr 05, 2018, 03:07 AM
I want to transform an old Futaba attak as to make a consolle, 2ch radio is perfect to have forward reverse and two on/off functions for lights and whistle.
This is the wooden railway I'm building now
Apr 05, 2018, 03:10 AM
some photos of my radio controlled locomotive finished.
it weight around 3kg (1600g locomotive 1200g tender without 3s lipo battery)
Apr 17, 2018, 03:44 AM
I'm building the transmitter by recycling an old 40mhz hitec flash 4 radio.
this allows me to move two trains with 2 auxiliary functions each.
the modified radio will enter part of the furniture in my sittingroom
May 29, 2018, 08:36 AM
new test in the garden.
(0 min 42 sec)
Discussion Skywalker X-6 swarm flying make dream come true!!! skywalker-ceo FPV Aircraft 3 Dec 16, 2016 12:32 AM
Discussion OcCre Mississippi R/C Steam Conversion SteamSurge Steam Boats 15 Jan 28, 2013 02:43 AM
Discussion OcCre Mississippi R/C Conversion SteamSurge Steam Boats 0 Jan 05, 2013 11:20 AM
New Product Ulises tug from OcCre patmat2350 Scale Boats 14 Jul 01, 2011 07:13 AM
