Thread Tools |
This thread is privately moderated by leonard3k, who may elect to delete unwanted replies. |
Data
Multirotors 4008q and 3508q, charts, methods, wind n power system planning
Hi, finally got something up here as blog
First blog and will add and edit, like a living document, please don't be offended if I delete something, will try to keep this short and neat like a manual Fun flier 3 cell 12v power using LIFE batteries, thrust for fav 3508q and similar is 2 to 3 pounds Here the first chart 3508q planned for wind either using 12x8 bush plane, 10x7 faster warbird, or 8x6 for a quiet prop jet The charts say it all too, text cannot be shifted in a pic! See how you like this idea, the chart is for HPdLRK wye only, 2x wire current spec Easy way to figure new turns for a new kv using old wind of same type, you can also use turn calculator, and see on the bottom of wind diagram, how each wind type relates by what multiples or numbers An earlier wind HPdLRK wye 14 turns 1105 kv 14 x 1105 = 15470 product divide product by desired kv and see what's close and divide by turns to zero in on predicted kv from turns 15470 product / 22 turns = 703 kv motor wound w 22awg hpdlrk wye good for 256 watts or a bit over 3 pounds thrust (10.668amps x 2 = 21.336tot amps x 12v = 256 watts) The low kv winds will likely need 22awg, stuffed it full on 26.5 turns and missed 5 turns on a 586 wind, so we can guess about increasing size as turns decrease I really like the diagram system I use, think about it, circled numbers are counter clockwise This link explains more about this diagram method: https://www.rcgroups.com/forums/show...-parallel-dLRK Third a chart on flight test FT Mustang scaled up with wire charts etc Now here's why I keep on trying to get the most thrust for the least amount of power, my 12v LIFE packs only come in limited capacity, but when tested with 586kv motor and gws 12x8, ran wot for 10 minutes continuous pulling about 10 amps!!! That's 2 pounds of thrust for 10 minutes load about 110 watts Next time I wind one of these, 22 turns 22 awg 703kv est 3# thrust 50mph apc e 12x8 from flybrushless thrust calc, definitely using the adjacent coil wind, yes! Leonard ImagesView all Images in thread
how much power for how much thrust, etc
I still like referring back to this gws 9x5 thrust chart, now even more
With a rewound motor at low 600 to 700kv and a 12x8 prop, 2# thrust takes 110 watts, 3# 209 watts Look at this 9x5 prop/thrust chart... appears to take just a little more power for the same thrust, see the motor that was tested too Am I doing any good, or is this persuit of more thrust for less power trivial? I get 3# for 210 watts with a 728kv hextronic d4023 and a gws 12x8 dd at 6.48 g/w Cobra 3520 -- 820 kv 12x8 apc e gets 52oz thrust for 332.3 watts 4.46 g/w that's an almost even comparison, but with a 12x6 they get 57oz 266 watts 6.13 g/w So I get 3# for 100 watts cheaper than commercial deltas, but, that extra kv you don't need, cost more in watts! change in pwr expected on the above ft mustang chart, (820kv/728kv)^3= 1.429 1.429 x 210 watts = 300 watts for higher kv If I plan on using 12v and 12x8 props for 3# then 703 kv is all I need and all over 703kv is wastefull The larger stator motors give 3# thrust at lower kv, the scorpion 3020 at 624.6kv LRKy 0.84nls!!! nice numbers for 45.43oz see below pic Leonard ImagesView all Images in thread
I've been wanting to make a better looking wind of the iFlight 3508q, the last effort for more thrust-less power was wound with half turns and 5 missing turns. No more half turns, those bird nests on top look bad and prevent heat dissipation.
The limit how much wire can fit was reached 27 in slot of 22awg doubled is 54 x 22awg area... 54 x 0.326907397215mm^2= 17.653mm^3 (26.5t) 52 ....... = 17mm^3 (26t) The simplicity of the dLRK wye wind is beautiful, after some guesswork 13t 20awg for 595kv (26 in slot 13.5mm^3) 13.653a (75cm/a) x 12v = 164w about 41 oz thrust 13t 19awg for 595kv (26 in slot 16.9mm^2) 17.184a(75cm/a) x 12v = 206w about 48 oz thrust 595kv with 12v would yield 40oz thrust w 12x8 prop, so that would be the limit, the motor would probably only use 150 watts or less, been wanting to try another that gives 32oz thrust on low power I have some more 3508q motors ordered from iFlight and just got some green wire, hope to maybe wind some with two colors, hp dlrk wye adj coil wind You may really like this new AWG wire chart I made up with Luciens pdf Leonard ImagesView all Images in thread
Lowest powered 3s motor wind for 2# thrust
I wanted to experiment at the lowest kv that would still give at least 32oz thrust with either APC or GWS 12x8 props.
The last 3508 wound for efficiency g/w thrust Io = 0.65 amps, was 26.5t with about 5 missed turns 28t 23awg HP dLRK y for 553kv at first estimating .82nls (I like this term Manuel V shared) Wound n tested Io looked so good at 0.4 amps, so I'm using and guessing wot load estimation of 0.84nls instead of 0.82 7260rpm/13.10 volts = 554.2kv 13.6a(75cm) - 17a(60cm) --- 163w - 204w 60 inches of wire p-p = 0.10151ohms 0.84nls x 12v x 554.2kv = 5586rpm 12x8 props 42mph APCe 951g 33.5oz GWShd 999g 35.2oz APCsf 5k 42oz 38mph prop adapters in order coming from iFlight Leonard ImagesView all Images in thread
Low KV motor poor wire fill runs hot... running too close to wire's current limit
This idea was a flop, might have worked with an odd size between 23 and 22awg, this one was just too close to the limits of the wire
Just tested at 5340 rpm (2# thrust) gws 12x8 ep 12.38v 9.3amps 115.134watts and runs hot APC 10x6 ...6300rpm 12.6v 6.2a 78.12w 23.12oz 36mph 655.4g 8.39g/w I would have made a much better motor with 23 or 24t of 22awg like I was planning above This one should be easy to strip, didn't put too much epoxy on wires I'm going to check wot nls figure and add here later Leonard |
Problem with 28t 23awg motor solved
It's not poor wire fill, I kept on thinking about this; I used the 75cm/a rating and it ran hot ------ So it's best to use the standard 100 cm/a rating or plan your wind and motor load around the 100 cm/a ratings for cool running motors
All my 2# thrust tests run 12v with 12x8 props and use about 9 to 10 amps, this motor tested at 12.38v 9.3amps ran hot, so I think using the 75cm/a rating is a bad idea Wire fill? No. This 23awg motor was 99.3g AND the new motor I just wound same way with 22awg IS 101.3g --- Same wire fill --- Same motor gram weight.... What was different, the wire capacity, not the gram weight capacity(100g x 3w = 300w) 22awg 100cma = 7a hpy 14a ......... 75cma 8.53a hpy17a limit ---- cool running to 168w or about 43oz thrust 14a hpy 100cma 23awg 100cma = 4.7a hpy 9.4a ..... 75cma 6.81a hpy13.6a limit ---- runs hot just at 115 watts 32oz thrust hpy = half parallel wye Best to use wire charts for 100 cm/a for better cooler running motors Leonard |
Best improved HPdLRK wind yet get more wire on stator
Hi, this gets the most wire on the stator winding HP 12n14p or any similar, wind first coil the odd #1 let #2 hang while you wind #3 nice and neat like #1, then fill in #2 even however you can get it to fit.
The original one Manual V and Trug came up with was nice, it eliminated some stator crossings but it always put the two strands BIG FAT ending coil winds next to each other, so my idea is to just alternate fat and skinny winds aka strand starts and ends evenly by pointing all arrows around the stator so they go start, end, start, end....... the starts always are wound first and evens are stuffed between, still leaving you the option to finish your motor even if you have to short the even winds by 1 turn to make it. As always stated before, circled #s are counter-clockwise wound. |
Thread Tools | |
Similar Threads | |||||
Discussion | Largest Hospital System In N.Y. Drops Obamacare Plans Citing Major Losses | kenpoprofessor | Life, The Universe, and Politics | 12 | Aug 26, 2017 09:52 AM |
Discussion | 2217 Suppo the "Beef" motor... what wind n termination? | leonard3k | Electric Motor Design and Construction | 37 | Oct 08, 2015 02:57 PM |
Discussion | Choosing power system - the simple method | Rogue.insight | Multirotor Drone Power Systems | 27 | Jan 04, 2015 11:52 AM |
Discussion | EZ Match power systems and charts from CSRC | BruceSund | Power Systems | 4 | Jul 17, 2008 01:30 AM |
Permax 480 Motors ... Suck'n Wind | Captain Carlton | Foamies (Kits) | 9 | Apr 17, 2002 01:39 PM |
