Mar 23, 2018, 12:18 PM
Site Aspie
Lynxman's Avatar
3D printed 120mm EDF - 3D printed 1:6,5 scale L-39
I'm trying to make a high thrust to watt 3D printed 120 mm EDF, and might design a printable plane around it. Possibly a big UL-39 Albi. I have an old Neumotor 1907/2Y motor, which is good for 900 W continous, and 1800 W peak, which I designed the fan around, using 8S batteries.
I'm testing different blade designs to try to achieve a high thrust to watt ratio. I get 2000 g thrust at 850 W and 3700 g thrust at 1750 W with the latest 12 blade fan I printed. 1750 is a little too much for the little motor, so that's probably why the efficiency is lower at that level. 2000 g at 850 W is pretty good though. The fan was printed with 0,2 mm layers and hasn't been sanded or smoothed in any other way. I'd like to test the fan to destruction, but I don't have a motor or ESC powerful enough to do it.
It sounds good too. At first I had the stators very close to the fan blades, and that gave slightly more thrust, but screamed quite a lot too. When I moved the stator 15 mm away from the fan it turned into a woosh fan.
EDIT:
The plane was finished a while ago and the files are availabloe from here:
https://cults3d.com/en/3d-model/vari...for-120-mm-edf
If you previously bought the files and want to get the updated versions you can redownload from your account.
Mar 23, 2018, 02:07 PM
You might try to make rotor blades that look like this - note the shape of the leading edges. More efficient...
Mar 23, 2018, 02:27 PM
Site Aspie
Lynxman's Avatar
What's the pitch distribution along the blade? Is it constant?
Mar 23, 2018, 08:55 PM
erh7771's Avatar
Are you using an intake lip?
If you can get close to 1 lbs of thrust to 250 watts that would be breaking some ground in my experience so 5000 watts would be 20 lbs of thrust
If you can engineer a contra-rotating rotors (not counter rotating) my understanding the efficiency could go up to max of 16%
really neat project
Do you mind sharing the .stl files?
Regards
Mar 24, 2018, 06:15 AM
Site Aspie
Lynxman's Avatar
I get 930 g at 250 W. That's more than two lbs. It's a small motor wo it's most efficient at low power. I use a bell intake when I test. The thrust is a lot lower without the bell intake.
I attached a photo of my test stand. A 5 kg kitchen weight with a 3D-printed stand.
I changed to an 11 blade fan now which I printed before. Rough figures:
910 g at 250 W
1500 g at 500 W
2000 g at 750 W
2500 g at 1000 W
3600 g at 1700 W full throttle.
Mar 24, 2018, 06:58 AM
Site Aspie
Lynxman's Avatar
Here are the files I made so far:
https://www.thingiverse.com/thing:2838324
Mar 24, 2018, 07:53 AM
Site Aspie
Lynxman's Avatar
I ordered one of these now to test higher power: https://hobbyking.com/en_us/turnigy-...eli-880kv.html
Mar 24, 2018, 10:16 PM
erh7771's Avatar
Originally Posted by lynxman
here are the files i made so far:
thx !!!!
Mar 24, 2018, 10:20 PM
erh7771's Avatar
Good choice of motor, I think someone took it past 6000 watts and it doesn't burn up but with brushless motors its a crap shoot, so many variables in their design.
Mar 24, 2018, 10:32 PM
erh7771's Avatar
910 g at 250 W
1500 g at 500 W
2000 g at 750 W
2500 g at 1000 W
You have a pretty efficient fan design so far, I'm sure the 1907 can absorb more than 1700 watts too
Looks like you're using a 675 kv motor
Do you have a 12s esc?
Thx in advance
Mar 25, 2018, 04:06 AM
Site Aspie
Lynxman's Avatar
I currently only have an 8s ESC. I ordered a 12S ESC with the new motor. Yes, 675. The 880 kv motor should give a good power boost at 8S. I'd like to have a cool running motor and good static thrust at 8S if I'm going to design a 3D printable plane around it. I use 8S 4200 mAh batteries for most of my big planes, and would like an EDF that has great low speed performance.
Mar 25, 2018, 09:10 AM
Site Aspie
Lynxman's Avatar
BTW, the 1907 motor is very short, and only weighs 232 g. It's an amazing motor for the size, but it gets hot at 1700 W. I'm really looking forward to seeing what the thrust figure will look like with a motor that runs those power levels more efficiently. The thrust at low power, 250 and 500 W, is very promising if it scales well.
Mar 25, 2018, 09:53 AM
Site Aspie
Lynxman's Avatar
Here's a screenshot from 3D Studio Max 2018. The colored spirals are the pitch guide lines I use for the different positions along the blade. I am trying different blade shapes and pitch distributions.
Mar 26, 2018, 04:20 AM
Site Aspie
Lynxman's Avatar
I'm going to make an 11 blade version of the one that gives the most thrust per watt so far. The difference between the different fan shapes is pretty small. The pitch is 360 mm, which gives a pitch speed of 350 km/h at 16200 rpm, which is 80% of the calculated unloaded KV speed at 30 V. I think I could make the fan lower pitch than this for more thrust per W, but it's hard to print it successfully because the blade angle becomes to shallow and becomes unprintable overhang unless I use support structure.
Mar 26, 2018, 12:07 PM
Site Aspie
Lynxman's Avatar
I turned up the cooling a little and will try to print a 13 blade fan with 300 mm pitch. Hope it goes well.
Discussion 3D printed 70mm EDF planes pavlis 3D Printing 21 Aug 21, 2019 03:08 PM
Cool 3D printed Vectored Thrust nozzle unit and EDF housing (new 64mm EDF housing) Arxangel Foamy EDFs 23 Aug 16, 2019 08:37 AM
New Product FD120 120mm 3mm Arm Thickness 3K Carbon Fiber Frame Kit with 3D Printed Partfor FPV Livershifter Micro Multirotor Drones 0 May 27, 2017 09:39 PM
Build Log Micro EDF Hawker Hunter - CAD, 3D Scanning, 3D Printing etc meerkat13 CAD/CAM 1 Mar 14, 2014 08:02 AM
Build Log F-Sweep XL KFm4 64mm EDF /w 3D printed EDF housing (64mm EDF housing installed) Arxangel Foamies (Scratchbuilt) 1 Jul 30, 2013 03:30 PM
