Mar 23, 2018, 01:11 AM
New Product
Durafly SLOWPOKE
In stock now!! Durafly SlowPoke 1200mm
The Durafly SlowPoke is an EPO foam model of the classic balsa design. Adding to the easy flying design of the SlowPoke, Durafly has added some larger wheels to make it even easier to take off and land on a wide variety of local fields. A great plane for your first low wing tail dragger or for the discerning experienced pilot wanting a great looking plane.
Find it right here at your local warehouse, use the following link with coupon code "Hobby10king" to get an extra 10% off:
Durafly™ SlowPoke 1200mm (47.2) PNF
€ 117,- seems like a good deal to start with
[Edit]
UPDATE: Also available in RED color now! Get it HERE !
Coupon discount codes: 20% 'GEARUP' and 10% 'HKRCG10
(codes may be expired by the time you read this, but just try them out)
Durafly SlowPoke 1200mm (47.2) PnF - HobbyKing Product Profile (8 min 47 sec)
Durafly SlowPoke 1200mm (47.2) PnF - HobbyKing Product Video (2 min 34 sec)
This will be regularly updated opening post with more info as it gets available in the thread
Durafly SlowPoke - Maiden HD (5 min 31 sec)
Durafly SlowPoke : 4S Fun! (6 min 9 sec)
Sorted thread info:
Wingspan: 1200mm
Lenght: 940mm
Motor size: 3648 700kv
ESC: Aerostar 40A
Prop size: 12x9"
Weight: Flying weight: 1380g
Lipo size: - 3S 2200 / 2700 [4S 2200 / 2650 - prop down]
Correct CG: - 80 / 85mm (start at 80mm's)
Radio setup: 4ch minimum
Wheels: - Size 100 x 28mm - Weight 33,5 gram
Stattic test: See paultbg's post HERE
Build tips:
- Check tailwheel / reglue the plywood disk before you glue on the tail!
- Use slow curing glue on the tail!
- Use bigger screws on the landing gear retainer.
Mods:
- moving pilot example HERE
- FPV cam pilot mod by yorkiepap, info can be found HERE
- 4S setup: replace ESC with a 50A for example: Hobbywing 50A ESC
Lipo: 4S 2650mAh 45C will give around 8 to 10 minutes flight time! (Graupner E-prop 12x6")
etc
etc
Mar 23, 2018, 01:12 AM
Sorted thread info
[edit]
Moved info to opening post.
Mar 23, 2018, 02:04 AM
paultbg's Avatar
they should have blur it a bit more, it's too damn obvious... !
Mar 23, 2018, 02:14 AM
Was very obvious to me because Steve told about it in the podcast.
If I remember correct they where already in the warehouse(s) so might be released "soon".
Mar 23, 2018, 02:49 PM
DFS#000178
Rampage's Avatar
If it's balsa I'll buy one.
Mar 23, 2018, 05:27 PM
For now I had the idea it would be just a foamie, but if I remember correct now Durafly had a few balsa models in the past.
For balsa I would normaly think of E-flite / hangar9 etc. but have to say the AIroso F3A and that funny E-Fair glider I got from HK where great value for money!
So yeah if it's balsa and ok quality that would be great, but I don't mind good quality foam at a very fair price either.
Mar 23, 2018, 05:46 PM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
Here is a couple of teaser photos from facebook!!
LURCH
Mar 23, 2018, 06:01 PM
LURCH
Thanks!
Well foam it is.. but these teasers already look great!
Mar 23, 2018, 10:44 PM
DFS#000178
Rampage's Avatar
That pilot figure looks fantastic.
Mar 28, 2018, 01:21 AM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
LURCH
Originally Posted by Justapoke
Thanks!
Well, here are a couple more pictures!
LURCH
Mar 28, 2018, 03:47 AM
Fly Eat Sleep Repeat
Andy852's Avatar
Slow Poke closeups here (a bit)
Aukey Optic Pro 2X Telephoto Clip On Smartphone Lens - HobbyKing Super Daily (2 min 12 sec)
Mar 28, 2018, 05:14 PM
Closed Account
-Durafly Slowpoke
EPO
Coming soon!!
Stephen
Mar 28, 2018, 06:55 PM
Define 'soon'.
I have money and am horrible at saving it and was going to buy a Slowpoke kit.
Mar 29, 2018, 12:33 AM
Well it’s not very soon, so not in the coming weeks I’m assuming
Mar 29, 2018, 02:02 AM
I had the larger balsa Slowpoke (converted to electric with lots of power) and hated how it flew... nostalgia hit me hard but somebody should have smacked me in the head before I bought it
A light-weight EPO version might be okay.
Discussion Advice on Slowpoke Sport 40 mbioman Fuel Plane Talk 15 Jan 29, 2018 06:39 AM
Discussion Slowpoke ARF for my son ng8264723 Fuel Plane Talk 4 Feb 13, 2017 06:58 PM
Discussion SlowPoke Sport 40 RC Man Balsa Builders 5 Oct 08, 2016 04:06 PM
Discussion SlowPoke Kit RC Man Electric Plane Talk 1 Sep 30, 2016 08:08 PM
Discussion To Durafly or not to Durafly! G. I. Flyer Electric Warbirds 7 Sep 02, 2014 03:42 PM
