Mar 21, 2018, 05:44 PM
New Product
FrSky VANTAC High Speed AR+ FPV Delta Wing
Available in:
Banggood
HorusRC
Not the cheapest wing in market, but definitely high quality which comes with FrSky S6R receiver, 80a ESC and 2208 3000kv motor!
VANTAC AR+ Wing has white EPP molded wing and fuselage, plus a built-in carbon fiber spar which makes the structure durable, rigid and lightweight. Detachable wings and wingtips make it portable and easy to take anywhere for FPV flying. Multiple bonus camera mounts, compatible with all FPV HD cameras in the market. It is easy to hand launch, super stable and fast. Flying speeds range from 20km/h – 180km/h. Wingspan is 900mm with a high-efficiency airfoil, which creates high elevating authority. Spacious equipment bay for all your FPV gear. Removable battery slot for better “CG” adjustment. “CG” bump mark under the main wing for easy balancing. AR+ Wing also has 2 skids for hand launching and landing. “NACA” Air inlet and outlet for cooling FPV gear.
Description:
Wingspan: 900mm(35.43″)
Length: 482mm(18.97″)
Flying Speed: 20km/h – 180+km/h
Specially tuned by FrSky, upgraded motor and super duty ESC.
Pre-installed S6R 6-Channel Receiver with 3-Axis Gyro features stability augmentation and Smart Port Telemetry.
Bright LED lights
Carbon fiber hatch handle
Net Weight: 376.5g
Features:
* White EPP molded wing and fuselage, plus a built-in carbon fiber spar which makes the structure durable, rigidand lightweight.
* Detachable wings and wingtips makes it portable and easy to take anywhere for FPV flying.
* Multiple bonus camera mounts, compatible with all FPV HD cameras in the market.
* Easy to hand launch, super stable and fast. Flying speeds range from 20km/h – 180km/h.
* Wingspan is 900mm with a high efficiency airfoil, which creates high elevating authority.
* Spacious equipment bay for all your FPV gear.
* Removable battery slot for better “CG” adjustment
* “CG” bump mark under the main wing for easy balancing.
* 2 skids for hand launching and landing.
* “NACA” Air inlet and outlet for cooling FPV gear.
Recommend Parts (Not Included):
Battery: 3-4S 1300-2200mAh 25C-100C Lipo
Compatible Cameras: Gopro H3/H4/Session, Runcam2/3 HD, Foxeer HS1177
Package Included:
1x Vantac AR+ Wing 900mm wingspan EPP FPV flying wing KIT
1x FrSky S6R receiver
1x FrSky FrBLS_80A BLHeli 32bit ESC includes 5V&12V BEC
1x Vantac Solo 2208 3000KV Motor
2x Gemfan 5152 tri-blade props
1x LED strip
FrSky VANTAC High Speed AR+ Wing Quick Promo (0 min 55 sec)
Mar 22, 2018, 12:29 PM
paultbg's Avatar
More than double the price of the regular AR wing (209 vs 89 USD) because they have added a receiver with gyro that cost actually 30USD. And call it Frsky wing.
Now that's a "great" deal.
BG, HorusRC - you guys have smoked something and it's afecting you...
Mar 23, 2018, 03:25 PM
P.I.Engineer's Avatar
Prop on backwards?
Mar 24, 2018, 02:50 PM
USA: LakeGeorge, New York
...cant fool the FPV community..
This plane is rebranded
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Mar 26, 2018, 02:57 AM
Yup
Nov 13, 2018, 02:28 AM
CrashAndBash's Avatar
I know this is a rebranded AR Wing...
I just picked one up on a hobbyking sale for USD $ 85. Not sure if EPP or EPO as I have seen it listed as both. I hope it is EPP.
I think I just bought it as the cost of the parts way exceeds its value and I was considering buying both an AR wing for an inav build and an S6R or S8R receiver for another non-flight controlled wing I have.
S6R = $30
frsky telemetry esc with 5v & 12V bec FrESC32_80A = $50 : 80 amp esc seems totally over the top.
AR wing kit = $70
Servo's = ?? : I don't know if they are plastic, anologue, digital or hopefully metal gear digital ( scary thought plastic servo's in a high speed wing )
motor 2208 3000 kv : A 3000 kv motor may be too noisy for my local park, so I may use a lower KV motor.
Anyone got one?
Nov 13, 2018, 06:23 AM
Head NEAT geek
Tom Hunt's Avatar
Anyone got one?
it's more than likely EPO, you cannot get that finish in EPP. Looks tempting, but I have more than enough flying wings now.
good luck!
New Product Sonicmodell F1 Wing 833mm Super High Speed FPV EPP Racing Wing Kit/PNP D Gains FPV Aircraft 298 Feb 18, 2019 08:38 PM
New Product FrSky Vantac AR+ Wing 900mm Wingspan High Speed EPP FPV Flying Wing RC Airplane BNF smg24 Banggood.com 0 Mar 21, 2018 05:19 PM
Discussion Sonicmodell F1 Wing 833mm Wingspan Super High Speed FPV EPP Racing Wing RC Airplane scousethief Banggood.com 0 Aug 03, 2017 07:57 AM
Discussion High AR 59" flying wing sailplane bmblb Foamies (Scratchbuilt) 16 Jan 26, 2016 11:23 PM
Discussion Wing-Loading, Speed and AR benm92 Electric Plane Talk 10 Oct 16, 2015 07:52 AM
