This thread is privately moderated by halicopter, who may elect to delete unwanted replies.
Mar 21, 2018, 12:40 PM
halicopter's Avatar
Gallery
My xk x130
after an hour and a half flight time (and a few crashes )indoors and out ,mostly fpv the x130 is holding up well and so far probably my favourite quad yet (only had a couple)
very similar to the x100 but so much better feel to it, hopefully last longer than 5 days !
changed the camera for one I had (for PAL and slightly better under low light
would definitely recommend one
Mar 26, 2018, 04:00 AM
halicopter's Avatar
would seriously advice (if not necessary ) the X6 transmitter if using 3g (acro) far too twitchy without it (for me ) .
on another note.... treated it to a nanotech 750
just arrived so test that soon
definitely recommend the nano .. my stock battery is already started to fade after only 30-40 cycles
nano good punch ,slightly longer running
Mar 27, 2018, 01:58 PM
halicopter's Avatar
cable ties for prop guards
so after killing the prop guards, made some from cable ties ..not as good as originals ..but better than nothing
will do till I source some parts for the x130
Mar 27, 2018, 08:43 PM
halicopter's Avatar
just can't help myself
so decided to bore out the old faithful tri blade props that came with the now dead nikko ,not had a good test yet but seems more controllable in 3g ,but also seems to have got rid of that terrible dive in one direction or other after you yaw hard or spin..time will tell .
but still loving this FPV experience
learning 3g FPV is like going back to the first shot of 3g on the v977/110 (line of sight)
Apr 02, 2018, 12:02 PM
halicopter's Avatar
10 hours in
so 10 hrs flight time and still going strong.. few crashes and has easily out lived all my previous quads ...thank goodness for hot glue
couldn't resist a lick of orange paint ...probably should have left it
after calming the setting on the X6 getting used to 3g /acro
just like the heli a lot more freedom
Apr 14, 2018, 08:45 AM
halicopter's Avatar
some new blades... so over 15 hrs in still going ....takes my abuse... will take anyones
Jun 05, 2018, 09:56 AM
halicopter's Avatar
41 hrs in
amazing little quad ....I has taken my abuse for over 40 hrs (has had a set of motors) ,I cracked the frame hitting the side of the house then the ground flat out ! still going strong, it even got dunked in a bowl of water for about 30 seconds !!!
this is definitely as bullet proof as xk k110
added jst for better battery connection
Jan 08, 2019, 09:35 AM
battery issue
hey,
i have a question.
i bought the same kwad few months ago, very pleased with it.
now recently i bought some extra batteries
1s 3.7v 750mah 30 c but everytime my throttle hits 75 - 80 percent
the kwad shuts itself down.
Is the discharge vallue to low or high?
Thankx , Tom
Mini-Review XK X130-T (incomplete review) canino Micro Multirotor Drones 38 Jul 20, 2018 10:29 AM
Alert XK X130-T RTF New Years Deal $59 fastmax Micro Multirotor Drones 1 Jan 16, 2018 08:14 AM
Mini-Review XK X130-T Micro FPV Sport Drone Flight Test Review t00nz843z Micro Multirotor Drones 3 Dec 11, 2017 11:44 PM
