Mar 19, 2018, 09:35 AM
I'd rather be flying.....
JeffMac's Avatar
Build Log
CAP 2018 - The Colt 35 - Flight videos added 6-22-19+7-1-19
Some years ago, I began construction of A. Schwemmer's " Colt 35 " from American Aircraft Modeler.
After moving and setting up the hobby room - some soul searching took place. I have no reason to build new planes with neglected, unfinished projects such as this one taking up space, and not flying.
So 2018 will be the year to complete the Colt. I'm building it from my original scans from the AAM - the Colt is a large ( for me ) single channel trike gear, high wing model. Mine is the original size.
We do not have internet access at our new house so posting has slowed considerably - I will add pics when possible. The fuselage, tail assembly, and wing are all built ... covering has begun on the stab, the wing is being prepped.
i'll link outerzone's plan ( Thanks Steve and everyone ).....
https://outerzone.co.uk/plan_details.asp?ID=7105
more later,
jeff
Mar 19, 2018, 11:14 AM
I like real wooden aeroplanes!
Sundancer's Avatar
Nice to see you back at the balsa face Jeff, I'll post the Colt entry in the CAP2018.
Mar 19, 2018, 01:57 PM
Welcome back Jeff! Nice looking design.
Mar 19, 2018, 02:05 PM
Like they said, glad to see ya' back and building ! I hope the new place is working out nicely, Mike
Mar 19, 2018, 02:32 PM
owlsabie's Avatar
Sounds fun Jeff! Happy gluing
Mar 19, 2018, 07:08 PM
Culper Junior
Godspeed Jeff!
Hard to turn a good balsa project down.
Mar 21, 2018, 09:16 AM
JeffMac's Avatar
George - thanks for the nice comments - the Colt should be a nice flyer for me....
RobtP - thanks, the Colt is simple but just appealed to me... hopefully it will fly well....
Mike - thanks for the nice words
Al - thanks for the nice words ... yep, it should be a good one.... a 1966 classic....
Jim - thanks.... yes, this one has been setting for a long time. at least I had it covered so no dust or sediment got into the wood....
jeff
Mar 21, 2018, 09:22 AM
JeffMac's Avatar
The new house is wonderful but was a lot of concentrated effort that left no time for my main Hobby ..... but , that is over now.
The Colt 35 wing had been covered but was a horrible result - thick fabric with brushed on white waterbase paint looked awful and weighed more than the structure of the 66" wing. It was promptly stripped and is being recovered now with polyspan.
It's amazing (all over again) how a material / supply surplus turns into a shortage as the planes get larger More polyspan needs ordered, only one wing panel bottom section and the stabilizer are covered...
The Colt 35 will be flown electric with no special tricks to lighten it up - the weight goal is no more than 5 lbs. Keeping it simple and hopefully able to fly in varying conditions is the goal. The motor is one obtained from BP hobbies several years ago and one flies my 60" Balsa USA Stick 40 size at 5 lbs on three LIPO cells with authority. Another one I have in stock will be used on the Colt 35...
More later,
Best regards,
jeff
Mar 25, 2018, 09:16 PM
JeffMac's Avatar
Some progress was made this weekend - the elevators we're hinged and installed, the rudder formed , hinged and installed..... Polyspan applied and clear WBPU applied..... Looks OK, some pictures were taken and will be posted soon.
I found the motor , it's a. 3520/6 outrunner bought from BP hobbies several years ago. These worked well so I bought several real
ly cheap......
More later,
Jeff
Mar 26, 2018, 06:59 AM
Brighto?
Mike Denest's Avatar
That's a nice selection Jeff. The Colt 35 looks to be an enlargement of the Milt Boone designed Charger which was kitted by Ambroid. The incidence angles of the wing and stab look exactly the same, the construction is similar with the exception of the vertical stab and rudder. Here's the plan links to both the AM plan and the Ambroid plan. What are you planning for controls? I'll bet dollars to doughnuts that if you fly it as rudder only, it will fly exactly the same way as the Charger.
https://outerzone.co.uk/plan_details.asp?ID=464
https://outerzone.co.uk/plan_details.asp?ID=2903
Mar 26, 2018, 09:19 AM
JeffMac's Avatar
hi Mike -
Thanks for the comments..... RET is planned for this bird..... I agree it would fly fine with rudder and throttle but elevator has been added..... I'm sure i'll try rudder only aerobatics
The Colt just looks like a really nice flyer - if there was any deliberate copying from the Charger to the Colt, the designer picked a worthy model to base his off from , of course....
Best regards,
jeff
Mar 28, 2018, 05:13 PM
JeffMac's Avatar
Some Colt 35 pics
All -
Finally, a breakthrough. Uploading pics from the cell seems to be working so here goes.. Nutmeg the indifferent shop helper , shows his enthusiastic side...
More later,
Jeff
Mar 31, 2018, 11:47 AM
JeffMac's Avatar
More progress with a pic...
The Colt 35 is moving along, but lots left before completion.. after ten years, I have to actually buy new full size standard servos..... Never thought I would be doing that😊
More later,
Jeff
Mar 31, 2018, 11:51 AM
Culper Junior
Nice engine display Jeff, looks like each might have its own memory.
Apr 03, 2018, 09:45 PM
JeffMac's Avatar
Thanks Jim.... They do have stories, some I know, others I never will know.
Colt 35 update - polyspan needs ordered to finish the wing covering... Dowels have been installed for wing and stab rubber bands. Two servos will be obtained this weekend from a Hobby Shop I will be near.
More later,
Jeff
Build Log Cub Canard for - CAP 2021 - somewhat test flown JeffMac Vintage & Old-Timer Designs 92 Jul 17, 2021 09:30 PM
Build Log Little Arcy - now CAP 2019 RobtP Vintage & Old-Timer Designs 17 Feb 26, 2018 07:31 PM
Build Log Ted Strader Easy One Now CAP 2018 pulserudder Vintage & Old-Timer Designs 39 Jan 08, 2018 06:02 PM
Poll EPO Grumman TBF Avenger (Lets Vote on the Wingspan) Suppliers Challenge for 2018 LordEmperorTeng Electric Warbirds 78 Dec 04, 2017 06:34 PM
Discussion Blade Runner sequel=2018 dll932 Life, The Universe, and Politics 9 Feb 19, 2016 03:06 PM
