This thread is privately moderated by ariaAQ, who may elect to delete unwanted replies.
Mar 19, 2018, 01:11 AM
ariaAQ's Avatar
Mini-Review
Bernoulli 3515 500kv - 2nd test - 6S with 1248 and 1447
Hello, this is my 2nd test.
Loong test... to make it close to the real flight situation..
Bernoulli 3515 500kv - 2nd Test 6S with 1248 & 1447 (16 min 51 sec)
Now lets see the motor first:
Came with built in 20A ESC (35A burst) and bright LED light.
Inside the box we can find:
- Manual
- Direct mount propeller adapter and screws.
- Standard mount propeller adapter (CW thread) and screws + M6 Lock nut.
- 50cm Power Wires with XT-30 plug.
- 75cm Signal Wires (optional length),
- Motor mount screws.
Motor designed to withstand extreme condition, so we don't need to worry about wet condition since the ESC already coated
- Motor = 167g (ESC and LED included)
- Power Wires 16AWG 50cm + Signal Wires 75cm = 28g
- Standard prop mount with 4 M3 screws = 12g
- Size: 42mm x 48mm
Built in ESC:
- No need for settings, just plug and play! this is good! => Simple to build, neat result,
- 20A (35A max burst) 4-6S rated ESC's should be enough for most application,
- ESC far away from sensitive equipment, especially compass,
- No ESC replacement, Marc from Inspired Flight guaranteed for Whole Motor Replacement if something going wrong with the motor.
How to set the LED (Video on my 1st test https://www.rcgroups.com/forums/show...nd-Led-Light):
- Press 0.5 second to change light color (default Green), => Green-Yellow-Blue-Magenta-Cyan-White-Off-Red-Green
- Press 5 second to change light pattern (default Solid),
How to set motor direction (Video on my 1st test):
- Switch to change direction.
- Unplug power source
- Plug back power source.
Motor here: https://www.inspiredflight.com/produ...t=991685148678
Test condition:
- 800m above sea level
- Two different propellers, CF-1248 and CF-1447.
- Fully charged batteries, 2x3S 1100mAh 25C in series, Quadcopter ≈ 6S 4400mAh 25C ≈ 6S 8800mAh 12C
- Reversed test, max PWM first just want to know about the max thrust with fully charged battery.
- Throttle position between 40-75% to simulate in flight situation.
Carbon Fiber 1447 Props Average Test Result (40-60% throttle), 6S :
Code:
  A         W         g         g/W       thr
3.72       82.50     762       9.24      40%
4.80      109.49     910       8.31      45%
5.99      131.88     988       7.50      50%
6.93      150.87    1070       7.10      55%
8.05      176.20    1213       6.91      60%
Should be good up to 1213g per motor.
Propeller here: https://hobbyking.com/en_us/multirot...asc=6211280862
Based on 8 minutes test,
- Max thrust = 2530g
- Max temp = 47.6C,
so motor capable to handle bigger props if more thrust needed, should be more efficient too..
To be continued....
New Product Bernoulli 3515 Brushless Motor - Integrated ESC and Nav Light MarcRacer18 Scratchbuilt Multirotor Drones 6 Mar 22, 2018 08:36 AM
Article Contest! - Bernoulli 3515 Integrated Motors Jim T. Graham Multirotor Drone Talk 96 Mar 08, 2018 07:11 AM
New Product Bernoulli 3515 Motor - Integrated ESC & Nav Light MarcRacer18 Power Systems 4 Feb 16, 2018 02:22 AM
New Product Bernoulli 3515 Brushless Motor - Integrated ESC and Nav Light MarcRacer18 Multirotor Drone Talk 0 Feb 15, 2018 05:19 PM
