Mar 16, 2018, 03:38 PM
XT90 Diameter
I've been searching all day to find the diameter of the plugs inside this connector. Some sites say 5mm, most say 4.5mm, one even said 4mm. Any one out there with an actual XT90 in their possession willing to measure it for me?
Clint
Mar 16, 2018, 04:21 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
Connector tests, dimensions, pictures
translate...www.elektromodellflug.de/hochstrom-st.-bu..html
Older version of that page, contains some other connectors
translate...www.elektromodellflug.de/oldpage/hochstromst/hochstromstecker.htm
Excellent site, do have a look at the controller-, motor-, charger-, power supply-, battery- etc. tests.
Prettig weekend Ron
Mar 16, 2018, 07:46 PM
Thanks! I actually just found the spec sheet from Amass themselves. It confirms 4.5mm. (Which is different than what is stated on HK)
Mar 17, 2018, 07:29 AM
Jack
jackerbes's Avatar
It says the contacts are "Brass Gold Plated" and I'll bet that is not true...
Jack
Mar 17, 2018, 08:03 AM
I'm not the pivot man
Jack
... yeah that is a little questionable. Contrasting the price between these connectors and the price of gold makes me skeptical.
Mar 17, 2018, 12:21 PM
translate...www.elektromodellflug.de/oldpage/hochstromst/hochstromstecker.htm ...
Several gold plated connectors in that test (a.o. 250A+ ), but gold is not mentioned for the XT30, -60 and -90's
Prettig weekend Ron
Mar 17, 2018, 03:57 PM
Jack
jackerbes's Avatar
There is a table here:
http://www.tibtech.com/conductivity.phpthst
that is titled
"Properties table of Stainless steel, Metals and other Conductive materials"
and it has the metals arranged with the best electrical resistivity at the top. And a gold plating would improve things over brass to brass contacts I guess.
Brass is worth about $2.00 a pound at scrap metal prices, gold is worth about $1,316.54 per ounce or $21,064.64 a pound...
Were any there, the tough part would be getting the gold off of the brass...
Jack
Mar 17, 2018, 07:40 PM
that is titled
Jack
Are you planning to fund retirement one XT connector at a time?😁
Mar 17, 2018, 08:00 PM
Jack
jackerbes's Avatar
That would be a heart breaker if that was my plan. I still don't think the gold is there.
And my retirement is covered now. I'm 76 this year, gave the Navy 26 years, have been retired for longer now than I was in, and my needs are all pretty well funded thanks to the Navy pension and Social Security.
Jack
Mar 17, 2018, 11:34 PM
Jack
Thank you for your service, sir.
Mar 18, 2018, 08:07 AM
that is titled
Jack
I am hard pressed to think there is any appreciable gold on any of the inexpensive connectors ... if any at all. However, what is common is a gold alloy where nickle and cobalt is added in the electroplating process. High end stereo/audio cables use gold plated connectors and the difference is sound quality is obvious when compared to standard cables. On these cheap Asian XT and other connectors I seriously doubt there is any gold of any value. Mostly an alloy of some sort.
Mar 18, 2018, 08:23 AM
Jack
jackerbes's Avatar
'..I am hard pressed to think there is any appreciable gold on any of the inexpensive connectors..."
I agree with that!
Jack
Mar 18, 2018, 08:34 AM
I am a nice guy! Really!
[QUOTE=jackerbes;39352010 . . . .
Jack[/QUOTE]
Gold prices are for Troy ounces. 1 Troy ounce = 1.097 oz avoirdupois so only about 19,200/pound.
The gold plating on contacts is very thin so very little gold is used.
http://www.te.com/documentation/whit...f/aurulrep.pdf
The plating process most likely is more costly than the gold used.
Mar 19, 2018, 03:24 PM
pilotpete2's Avatar
In pro audio, you won't find gold plating on microphone connectors, or any other connector that's going to be subject to repeated connect/disconnect cycles.
In home audio, a good quality gold plated RCA connector is great, since those interconnects are usually connected, then left connected for years in many cases.
Pete
Mar 23, 2018, 09:42 AM
Gold plating is for corrosion resistance and costs almost nothing in the amount that is deposited. Usually the Gold will be plated over a Nickel plating.
There is not much point plating connectors which are cycled as the plating soon wears away. The XT90s for instance wear through the gold in the first few times they are coupled.
Question Trex 600 electric connectors XT60 or XT90 2down Electric Power Systems 2 Jan 24, 2016 06:35 AM
Question On XT90 connector by venom those that actually use them exp/info/good/bad losi man Car Talk 0 Dec 08, 2015 12:21 AM
Discussion Batteries and XT90,XT60 modeh7 Multirotor Drone Power Systems 4 Sep 24, 2015 04:08 AM
