Thread Tools |
This thread is privately moderated by mlilasic, who may elect to delete unwanted replies. |
Mini-Review
Review of Dragonfly Hurricane 2207 KV2500 Brushless Motor for FPV Racer - FPVmodel
Review of Dragonfly Hurricane 2207 KV2500 Brushless Motor for FPV Racer from FPVmodel
Doesn't this motor look great? ![]() Build quality of these motors from FPVMODEL look amazing. Especially when taken into consideration their price. Quality/price ratio on this motor is huge. Hope their performance in flight quality will be equal to their looks&build quality. A great feature is also plastic ring along the bottom part of the windings that will prevent bolt, which is too long, to push against windings and damage the motor. What a great and simple idea. ![]() Air gap is nonexistent and on the bottom side of the magnets here are blobs of glue used to balance the bell. Also, another important aspect is that vertical play is nonexistent also. Bearings sound nice and smooth. ![]() Windings are OK: ![]() Weight with 11cm of wire is: ![]() ![]() In the box: ![]() motor locknut 5x screw ![]() I will be building one quad to test them so stay tuned for flight test videos... Text from FPVmodel website: Specially deisigned for FPV racing with extreme performance Fast response and ultimate efficiency New technology to ensure smooth running Precise balanced and fully tested Powerful, reliable, and quick. This is the latest Dragonfly Hurricane 2207 2500KV brushless motor that specially designed for FPV racing and extreme performance. These Dragonfly Hurricane 2207 2500kv motors feature an open air base to allow for more efficient cooling of the motors. Weighing in at just 30.5 grams helps eliminate some weight compared to other motors and fits with most racers desire to shave precious grams off builds wherever they can. Features: Featuring 20awg silicone wire, N52SH magnets and Japanese NSK bearings these motors are sure to fit the needs of most FPV racers. We use high quality aluminum and rare-earth magnetic materials, and redesigned the magnetic circuit of Dragonfly Hurricane to make sure the motors come with a better loading capacity. We have greatly improved their thrust and efficiency comparing to other motors on the market. At the same time, we have enhanced the response speed to guarantee the smooth flying of your racing quad The use of special aluminum material for body structure, not only comes with a greater strength than those motors made of the 6 series aluminum that most other motors use, but also greatly reduce the weight. The motor shaft has abandoned the traditional way of installation, the spindle completely goes through the threaded shaft to improve the friction between steel shaft and threaded sleeve of head cover. It also improves the concentricity of motor rotor and effectively increases the strength of propeller shaft, so that to make sure the motor can survive from the hard crashes. The Draongfly Hurricane has added an insulation film between bottom cover and spindle to isolate the connection between screws and copper wires. In this way, the motor is able to prevent from short circuit and leakage that caused by misoperation. Specifications:
Pros:
Cons:
Conclusion: Best Price/Performance ratio motor on the market. I highly recommend it. Grab yours Dragonfly Hurricane 2207 Motor HERE |
A quick comparison to other motors...
Hurricane is most similar in construction to Brotherhobby Returner. ![]() ![]() ![]() ![]() ![]() ![]() |
Unfortunately, I am having troubles with FC (FrSky XSRF4PO), so review is on hold until I get replacement FC.
Finally, the maiden flight:
Still, have to tune the quad but the motors&ESC combination seems to be great. |
This is my very first flight so I don't know about durability, we will see... The first impression is that they are very nice motors for their price. More videos are coming, so stay tuned. |
2nd flight
one without singing motors:
Thread Tools | |
Similar Threads | |||||
Discussion | SEEKING REVIEWERS !!! Dragonfly Hurricane 2207 2500KV Brushless Motors | FPV.Model | Multirotor Drone Power Systems | 85 | Oct 14, 2018 04:13 PM |
Mini-Review | FPV Model X-Racer KL100 - Runcam Nano, Emax F3 tower, DragonFly motors (review, wip) | SoloProFan | Micro Multirotor Drones | 16 | Sep 11, 2018 09:53 AM |
New Product | $13.99 Dragonfly Hurricane 2207 KV2500 Brushless Motor for FPV Racer | jaganfpv | Product Announcements | 1 | Feb 10, 2018 10:01 PM |
