Futaba 12K Series Radios - RC Groups
Futaba has released some new mid tier radios that use their T-FHSS technology. There are three versions, Air, Heli and FPV, and all are compatible with telemetry sensors and S.Bus 2 gear.
14 Channel S.Bus2 Radios
Futaba has released some new mid tier radios that use their T-FHSS technology. There are three versions, Air, Heli and FPV, and all are compatible with telemetry sensors and S.Bus 2 gear. They have back lit LCD screens and a scroll wheel for accessing menus and functions. All three radios are essentially the same with the main difference being the airplane version has a ratchet throttle and the FPV and Heli version has a smooth throttle. Each radio comes with a different receiver to suit the aircraft type and all are the same price at $449. This should be a quality radio for the mid level market.
Check out the new Futaba 12K Series Radios here
Transmitter Features:
  • Channels: 14 (12 proportional, 2 switched)
  • Compatible with T-FHSS and S-FHSS protocols
  • Six 3-position switches, two 2-position switches, two slider levers, two rotary dials, four digital trims and two push buttons for quick, easy access
  • Headphone plug, trainer port and S.Bus plug-in
  • S.Bus2 system allows multiple servos, gyros and telemetry sensors with a minimum number of cables
  • Model types: six types of main wing with three tail types for airplanes, six swash types for helis and multi-rotor functions
  • Improved stick feel with adjustable lengths and tension
  • Dual rates/exponential
  • Included 6V 1800mAh NiMH battery and charger
  • Large, backlit LCD screen with adjustable contrast for easier reading. Push/dial operation simplifies set-up
  • Micro memory card slot for storing model information and free system updates. (SD-32MB to 2GB; SDHC-4GB to 32GB, not included)
  • Vibration feature alerts pilots to various alarms and timers, in addition to sound
  • 10-character model naming
  • Expandable 30-model memory
  • 5 flight conditions (Helicopter and Glider model selections)
  • 5 customizable programmable mixes
  • Servo test and servo position display
  • Fuel mixing
  • Stick calibration
  • Servo speed
  • Logic switching
Airplane Features:
  • 6 wing types
  • 3 tail wing types
  • 5 flight modes
  • Pitch curve
  • Throttle curve
  • Throttle delay
  • Aileron differential
  • Flap setting
  • Aileron to camber flaps
  • Aileron to brake flaps
  • Aileron to rudder
  • Rudder to aileron
  • Camber mix
  • Elevator to camber
  • Camber flap to elevator
  • Butterfly function
  • Trim mix
  • Air brake
  • Gyro mix
  • V-Tail
  • Ailevator (dual elevator)
  • Winglet
  • Motor speed
  • Rudder to elevator
  • Snap roll
  • Multi-engine functionality
  • Airbrake
Helicopter Features:
  • Six swash types
  • Pitch curve and pitch trim
  • Throttle curve and throttle hover trim
  • Throttle hold
  • Swash ring
  • Pitch to needle
  • Pitch to rudder (revolution mixing)
  • Gyro mixing
  • Governor mixing
  • Timer settings
  • Throttle percent timer
Glider Features:
  • Glider-specific functions
  • 6 wing types
  • 3 tail wing types
Multirotor Features:
  • Throttle stick position warning
  • Gyro Sense
  • Flight Mode
  • Throttle Curve
  • Throttle Delay
Mar 15, 2018, 11:03 AM
Team Futaba
Silent-AV8R's Avatar
There is another thread on the new cool 12K with lots of info and discussion here:
https://www.rcgroups.com/forums/show...aba-12K-thread
Mar 15, 2018, 01:51 PM
RCG Admin
Jason Cole's Avatar
Thanks, this is a news article though which gets seen in more places than just the forum. Different kind of post than a discussion thread.
Mar 15, 2018, 03:55 PM
Team Futaba
Yep, just trying to point people to a thread where many questions have already been asked and answered. I suppose from your end it makes sense to have multiple threads, but if a person is trying to help answer question, etc. it gets to be a pain to try to keep track of multiple threads. Multiple threads also dilute the dissemination of information since the same info does not always end up in each thread.
Discussion Futaba 12K thread reverse Radios 51 Mar 21, 2018 12:02 PM
Help! Looking For Service Source For OLD Futaba FG Series Radio George Jure Radios 9 Mar 02, 2017 07:53 PM
Discussion Origin of Jimmie Allen and Captain Midnight radio series Pat Daily Free Flight 9 Mar 05, 2016 08:41 PM
Discussion Futaba FX Series Radio accesories prodriverex Radios 0 Jan 04, 2013 10:37 AM
Is it true that the Futaba FF8 series radio can support both positive/negative shift Magna Electric Plane Talk 6 Sep 23, 2001 06:26 AM
