Thread Tools |
This thread is privately moderated by mlilasic, who may elect to delete unwanted replies. |
Mini-Review
Review of Robotdog 35A 32Bit 2-4S BLHeli_32 ESC Dshot1200 from FPVmodel
![]() Robotdog 35A is a new 32bit BLHELI ESC from Battle RC that uses the latest BLheli_32 firmware. Dshot up to at least Dshot1200, and at rates up to at least 32kHz is now supported. If you are seeking for a small, powerful blheli_32 capable 32bit ESCs, the Robotdog ESCs certainly fit the bill providing 35Amps of power. * for a limited time, the Robotdog is sold at $9.9 only. Don't miss it out if you are building on a budget. The low price does not mean that the Robotdog is lacking power. It has all features a 32bit BLHeli ESC has!!! 35A designed, ARM 32bit Cortex-M0 MCU, 1500uF cap onboard, 2-4s input and Dshot at least Dshot1200. Specifications: Blheli_32 code ARM 32bit Cortex-M0 MCU Dshot up to at least Dshot1200 1500uF cap onboard 2-5s LiPo input (as per our test, no problem to use with 5S.) . 35A designed Weight: ![]() ![]() Dimensions: ![]() ![]() ![]() BLHeli_32: is the third generation BLHeli code, following base BLHeli and BLHeli_S. It runs on an ARM 32bit MCU, initially it will be on a Cortex-M0 running at 48MHz, but there are MCUs out there that can run a lot faster. ?BLheli_32 can run input signals with lower latency at faster rates. Dshot up to at least Dshot1200, and at rates up to at least 32kHz is now supported. Here is what BLHELI_32 has to say about their new "Power to perform": Programmable PWM frequency of up to 48KHz Auto-timing for higher efficiency and reliability Voltage/Current limiting Adjustable “Brake on Stop” force Improve direction change in Bidirectional mode Configuring from FC using DShot commands Pros:
Cons:
Grab yours Robotdog 35A ESC HERE |
Default settings of ESCs
Unfortunately, I am having troubles with FC (FrSky XSRF4PO), so review is on hold until I get replacement FC.
Finally, the maiden flight:
Still, have to tune the quad but the motors&ESC combination seems to be great. |
2nd flight of the quad
one without singing motors:
i was not chosen to review them, but i bought some to make the review for my channel.
Thread Tools | |
Similar Threads | |||||
New Product | Betaflight 32Bit 35A 2-6S BLHeli_32 ESC Dshot1200 | nitbeat | Multirotor Drone Electronics | 6 | Nov 11, 2019 06:08 PM |
Discussion | *Seeking Reviewers* Robotdog 35A 32Bit BLHeli ESC | FPV.Model | Multirotor Drone Electronics | 25 | Oct 12, 2019 05:00 PM |
