Mar 13, 2018, 07:36 AM
Quad Erat Demonstrandum
scousethief's Avatar
Eachine EV900 5.8G 40CH HDMI AR VR FPV Goggles 5 Inch 1920*1080 HD Display Built-in B
https://www.banggood.com/Eachine-EV900-5_8G-40CH-HDMI-AR-VR-FPV-Goggles-5-Inch-19201080-HD-Display-Built-in-Battery-p-1270784.htm
Compatible with multi devices via converting cables
Mini HDMI port:
iPhone : lighting to HDMI, need power( Power adapter or power bank 5V) video: become slightly lower resolution, audio: Okay;
iPad : lighting to HDMI, need power( Power adapter or power bank 5V) video: become slightly lower resolution, audio: Okay;
MacBook : USB type-C to HDMI
MacBook Air, MacBook Pro : mini DP to HDMI
TV : HDMI to mini HDMI cable
Laptop with HDMI : HDMI to mini HDMI cable
Laptop or PC with VGA, no HDMI : VGA to HDMI
V-in port (in this port, we have Video in / Audio out / functions)
Other RX devices : Video cable
Cameras with analog video/ CVBS signal : Video cable
TV : Video cable
Video out : When EV900 work on RX mode, analog video can be connect to a DVR recording device through this port.
Specification
Brand name
Eachine
Item No.
EV900
Item Name.
EV900 hybrid HDMI AR VR FPV immersive racing goggles 5 inch 1920*1080 built-in Battery
Screen
Screen size: 5.0 inch
Screen resolution: 1920*1080 (No blur after enlarge by the lens)
Screen brightness: 600cd/m2 with special high brightness backlight LED for outdoor FPV
Refresh Rate: 120Hz, offer better, sharp, colorful screen view
View Angle: 140/120 degree(Horizontal/Vertical)
FOV 85 degree, immersive larger screen
Greatlines Tech To make analog video with much more resolution TV lines. 3D noise reduction, Color enhancement…
DeepFeedback Tech Real voice audio technology, to bring in great audio enjoyment
Lens
3x boost of the video to acquire intense feel-in-there video;
92% transparent rate no distort of light;
New lens is NOT a Fresnel lens anymore;
New lens support 1080P
Battery and recharge
Built-in 3.8V/2400mAh battery;
Each battery circle offer around 2hr10min working time;
5-18V wide recharging voltage range, typical recharging voltage is 5V
Accepts 5V power banks or 2S(7.4V)/3S(11.1V) battery as back-up power to have long working time
Receiver
Build in 5.8G 40CH Raceband receive, ENHANCED with Greatlines technology
Frequency Table
Frequency Band A 5865 5845 5825 5805 5785 5765 5745 5725
Frequency Band B 5733 5752 5771 5790 5809 5828 5847 5866
Frequency Band E 5705 5685 5665 5645 5885 5905 5925 5945
Frequency Band F 5740 5760 5780 5800 5820 5840 5860 5880
Frequency Band R 5658 5695 5732 5769 5806 5843 5880 5917
Ports HDMI / V-IN(Audio out) / 2.5DC power charging port
Body
Dimension: 148x 146 x 120 mm
Weight: 330g with 2hr10min 3.8V 2400mAh battery
Belt: three-ways adjustable belt
Features
- 5 inch 1920*1080px HD high brightness 120Hz refresh rate screen
- With Greatlines technology DSP chipset, offer low delay (latency 20-50ms) and HD video wirelessly;
- With DeepFeedback technology audio enhance AP, deliver great audio enjoyment.
- Multi-use port can be used to work with many other devices*, more than FPV;
- New designed, HD optic system, support 1080P, and no blur;
- With comfortable face sponge and Video IN/Audio OUT function;
- HD high brightness 5inch LCD specially tuned for FPV racing;
- Built-in super sensitiveness 5.8GHz 40ch receiver, especially with RaceBand;
- Come with advanced auto-searching function ad show you the working frequency on screen;
- Built-in 3.8V/2400mAh battery, each full charge revive around 2hours 10mins working time;
- Wide range re-charge voltage 5-18V, power banks or 2S/3S batteries can be used as back-up power sour, to prolong the working time;
- Ergonomic design fit your faces;
- Super-wide visible angle up to 85 degree;
- 92% transparent lens adopted, no distort, no blur on the adage of screen;
- Light weight 330g with 2hr10min 2400mAh battery, RTF for any scale racing game.
Package Included
1 X EV900 AR VR FPV Goggles (Built-in 3.8V/2400mAh battery)
1 X StingPad Antenna
1 X K-loverleaves Antenna
1 X USB charger cable
1 X Battery charger cable
1 X AV IN cable
1 X User Manual
Discussion Eachine EV900 5.8G 40CH HDMI AR VR FPV Goggles 5 Inch 1920*1080 HD Display BGKevin FPV Equipment 28 Apr 04, 2018 07:11 AM
New Product Eachine VR-007 & VR-007 Pro 5.8G 40CH HD FPV Goggles SeByDocKy FPV Equipment 534 Dec 26, 2017 12:58 AM
New Product Eachine VR006 VR-006 3 Inch 500*300 Display 5.8G 40CH Mini FPV Goggles Livershifter FPV Talk 0 Jun 05, 2017 05:22 AM
New Product Eachine Goggles One 5 Inches 5.8G 40CH Raceband HD 1080p HDMI FPV kinicari5 FPV Equipment 3 Aug 06, 2016 09:11 AM
Alert 9% OFF Eachine Goggles One, 5 Inches 5.8G 40CH Raceband HD 1080p HDMI FPV Goggles abcdrone Banggood.com 3 Apr 16, 2016 02:35 PM
