Mar 12, 2018, 07:01 PM
DLord's Avatar
Build Log
Crossbow fl-S ---Exact Scale RC Model Design, Build and 3D Sailing Project
I'm almost finished with the design and build portion of the D2 project and have decided that I will design and build an exact scale rc version of the 18.75' Crossbow foil-assist monohull keelboat to allow testing of the concept and design.
The model will be about 65" loa with an ultra narrow 8.8" beam (not including overhanging seats and the Trapeze Power Ballast System).
I've worked on the Crossbow concept since 2012 and have recently decided that I wanted to improve the design to allow two people to sail the boat as well as be able to singlehand the boat. The original concept was a singlehander featuring a Trapeze Power Ballast System and the "original" DSS foils.
More soon.....
The new version is completely different but here is some detail on the original project:
https://www.boatdesign.net/threads/crossbow-fl.43615/
Pictures showing the original concept and concept(non-sailing) model:
Mar 13, 2018, 07:49 AM
A.B.'s Avatar
Please tell us you plan on sailing this latest boat before building a new one?
Mar 13, 2018, 09:49 AM
DLord's Avatar
"this latest boat"
Sure: I plan on sailing this latest boat before building a new one. Meanwhile, work on the design of the new boat continues........
Mar 14, 2018, 07:53 PM
DLord's Avatar
Crossbow fl-S
The new Test Model will use the D2 Trapeze Power Ballast System and possibly the same Welbourn "Q" foils:
Note-tip of foil has a 3 degrees+ twist to aid in early takeoff.......
Apr 08, 2018, 07:54 PM
DLord's Avatar
Crossbow fl-S ---Exact Scale Test Model Design, Build and Testing Project
This will be a fairly large test model at 65" LOA and should provide good results in testing-as well as being a fun model to sail. The full size version will be unique with its super skinny hull-narrower than a Zephyr or 110 with Welbourn "Q" foils capable of lifting the boat clear of the water.
For the model I'll probably be able to use the D2 foils and, maybe, the D2 light air rig.
The L/B ratio of the hull is a very skinny (for a monohull) 7.5/1 .
Zephyr 20 fter:
Discussion Ferrule Design Crossbow Gearbox CosmicDog Ornithopters 2 Dec 04, 2016 08:07 AM
Discussion JADE (Jarel Aircraft Design Engineering) Crossbow Electric RotoTillerGuy Sailplane Talk 5 Nov 24, 2016 10:06 AM
Build Log THERMALPLEX DLG - Design, Build, Test, Optimize, Produce, a Flying Wing DLG... RobertTHaas Hand Launch 254 Dec 31, 2015 06:42 PM
Cool Heli-chair Fly your scale model EXACTLY like a full size p4ddy Mini Helis 37 May 14, 2008 08:47 PM
Let's build a Winger Models One Design DR-107 Martin Hunter 3D Flying 153 Sep 11, 2007 07:42 AM
