Wire bending at sharp angles - RC Groups
Mar 11, 2018, 04:40 PM
I am trying to bend wire (for boom vangs and rigging screws) at a sharp angle. I want to achieve a "V"shape bend, but all my efforts result in a small "U" shape at the bend. I ordered a wire bending jig from Amazon, but it is not meant for the small gauge wire. Any ideas? What do some of you do to get that sharp angle?
Mar 11, 2018, 07:04 PM
Thomas Armstrong
So, it is not possible to bend in "V" shape, but I assume you need a very small "U", right?
Most tools I've seen allow for up to 90 degrees bend, that is when they hit the limit of their geometry. Like this one: https://www.youtube.com/watch?v=OIOXfqDXuV0?t=1
I'll say you need to start with the 90 tool, and then continue with handtools. Watch this (1:20 mark):
Mar 11, 2018, 08:16 PM
Micro-Mark still sells the set of metal forming pliers that I've been using for, I don't know, 30 years or so. Perfect for all kinds of hooks, etc.:
The other thing to get is a hand vise. With those two you should be able to form just about any wire shape.
Mar 12, 2018, 01:49 AM
The micromark pliers are awesome, highly recommended. Also check out the Dubro quick twist tool. The Youtube video on it is great. Ryan
Mar 12, 2018, 07:11 AM
https://www.duluthtrading.com/store/...der-28011.aspx I use this. works well on wires smaller than a coat hanger, once you get close to the bend you want you can use some pliers to finish the deal.
Mar 12, 2018, 05:21 PM
It looks like "minimum bend radius" is also called formability.
It looks the that number (where cracking is not observed) is VERY dependent on the material and tooling. It looks like brass wire has a minimum radius of "one" so you could make a 90*!of a 30 thousands wire on the shank of a 30 thousand drill bit.
If you need a sharp corner you can use a file to remove material or silver solder to add. Just made sure you have the mechanical strength you need.
Discussion Bending wire LG complexities packardpursuit Control Line 20 Sep 06, 2016 11:20 AM
Discussion Bending music wire revisited epoxyearl The Builders Workshop 28 Aug 27, 2016 05:04 AM
Question Bending music wire Marion The Builders Workshop 4 Aug 18, 2016 12:59 PM
