Kyosho Mini-Z MR-03S2 Harrod's McLaren 12C GT3 RC Car - 32243HR-B - RC Groups
This thread is privately moderated by CR125Honda, who may elect to delete unwanted replies.
Mar 10, 2018, 11:18 PM
Trader Rating: 10
$110.00 USD
Buyer pays shipping
Like New condition from estate sale.
I put batteries in to test. Everything functions as it should.
These are highly specialized RC vehicles made to run on prepared surfaces.
Research Kyosho Mini-Z tracks.
From Kyosho website -
From its launch in 2013 the MINI-Z Racer Sports MR-03 Readyset made it easy for a wider group of racers to enjoy the precision control of its MR-03 base chassis that built its formidable reputation on the MINI-Z racing scene. This next generation upgrade remains faithful to this original concept. One major upgrade is the advanced gyro unit (MZW431) that can be mounted on the Mini-Z AWD Sports, is also able to be mounted on the MINI-Z Racer Sports 2 MR-03. The gyro?s sensitivity can be adjusted through a volume control installed on the chassis. Redesign of the steering control setup to accommodate the gyro has resulted in higher degree of steering precision compared to the previous model. In addition, when used in conjunction with the KT-432PT transmitter (sold separately), the gyro sensitivity can be adjusted directly from the transmitter, regardless of the volume setting on the chassis. The same applies to steering force settings, which can also be adjusted from the KT-432PT transmitter. With these two functions, precise setting can be achieved to optimize steering feel to your individual driving style. The MR-03 chassis lays the foundation for the new racing experience of the MINI-Z Sports 2!
***The wheels shown on the car with the body installed, are the wheels that are included.***
MR-03 chassis is equipped with a special Sports 2 circuit board. Combines high performance and compatibility with all body styles.
Features the newly designed FHS 2.4GHz Perfex KT-19 transmitter. Equipped with trim to adjust the optional light unit.
In addition to the light unit, a special gyro unit (MZW431) can also be installed. Gyro sensitivity can be adjusted by turning the volume dial.
Chassis can be set to either narrow or wide tread by replacing the front lower and upper plates and steering tie rod. Of course the wheelbase can still be adjusted to suit certain car types. Changing the width and/or wheelbase is usually associated with a change of body, and may require the purchase of additional small parts.
Factory-assembled ReadySet is truly ready to go as soon as you install four AAA-size alkaline batteries in the transmitter, and four more in the car.
All MINI-Z Racer bodies can be installed. *Requires compatible motor case and diff gear assembly.
Features unique VCS (Variable Camber System) front suspension that delivers optimum camber change as the suspension loads and unloads from cornering forces.
Front coil spring lower mount can be detached with just two screws for easy replacement of the coil springs on front suspension.
A huge variety of standard replace parts and a large array of existing custom and performance option parts for the MR-03 chassis can be installed.
This model is specially designed for the KT-19 transmitter so there is no compatibility with the former KT-18 transmitter/EX-5UR ASF transmitter (No.82011). It is, however, compatible with the Syncro EX-6 and the Syncro Touch KT-432PT radios.
Factory assembled chassis
Pre-painted factory assembled plastic body finished with markings
2.4Ghz transmitter Perfex KT-19
Parts set for changing front tread
Front suspension spacer for adjustment
6T, 7T, 8T, 9T pinion gears
Wheel wrench
Pinion tools
Spare wheel nut
Tires and wheels included
4 x AAA size alkaline batteries or NiMH x 4 for chassis
AAA x 4 alkaline batteries for transmitter
Length: 124-133mm(MM Chassis:125-133mm,RM Chassis:124-132mm)
Width: 65-76mm
Height: 34-35mm
Wheelbase: 86-106mm(86,90,94,98,102,106)
Tread (F/R): (Wide)61.5mm / 59mm (Narrow)56.5mm / 56.5mm [when wheel offset is 0]
Tire(F/R): 23.5-258.5mm / 25-278.5-11mm
Gear Ratios: 7.3,6.3,5.5,4.9:1
Weight: 135g approx.
Motor: 130-Class
Sold Kyosho Mini-Z MR-02 MM McLaren + Enzo Ferrari body RTR jokeane Cars - Cars and Parts (FS/W) 1 Dec 16, 2017 07:08 AM
Sold iWaver 02 Clone of Mini-Z MR-01, Mitsubishi Lancer RC Car jokeane Cars - Cars and Parts (FS/W) 0 Dec 10, 2017 08:22 PM
Sold Kyosho MR-03S Subaru Impreza Mini-Z drabina Cars - Cars and Parts (FS/W) 0 Nov 29, 2015 06:19 PM
Sold Kyosho MR-03S Mini-Z Subaru Impreza drabina Cars - Cars and Parts (FS/W) 1 Nov 24, 2015 08:39 PM
Cool SKYRC RC Model Mini Car Gyro Unit for Kyosho MINI-Z Racer MR-03 szewang2805 Hot Online Deals 1 Oct 23, 2012 10:13 PM
