This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Mar 10, 2018, 06:42 PM
old4570's Avatar
FrSky D8 compatible Rx ( 4ch ) Part 2 - Range test
Previous post = Part 1 ...
Product page @ banggood
I bound the Rx to my Taranis Q x7 = Easy .... And then made a range test box . ( Pictured )
Bind process ....
I went into the menu of the Q x7 and created a new model ..
Then set the transmitter to D8 ( 1-8 ) mode ...
Then set the Tx into bind mode :
With the Tx in the bind mode :
Rx .
I had connected a UBEC to Ch1 and a servo to Ch4 ..
Before applying power I press and hold the bind button and whilst holding the bind button apply power to the Rx .
The bind is almost instantaneous ...
I let go the bind button and disconnected power to the Rx ... ( Get the Tx out of bind mode )
Turning on the Rx again - it was bound to the Tx ...
Putting the Tx into range test mode , I started walking away from my range test box .
Facing the Rx I made it to the maximum distance I can get from the Rx ( 60 meters ) ... And there was no issue ..
Facing sideways there was no issue ..
But turning away ( 180 ) from the Rx so that my body was between the Rx and Tx I did lose the signal ...
Jun 14, 2019, 06:12 AM
Thanks for doing this and the binding info
Slowly getting it together to solder mine 😀
New Product 2.4G 8CH D8 Mini FrSky Compatible Receiver With PWM PPM SBUS Output --FREE TEST BG Tobey Radios 46 Aug 14, 2019 04:49 PM
Discussion Banggood "2.4G 8CH Micro Frsky D8" range? bennymack Multirotor Drone Electronics 8 Dec 22, 2017 06:45 PM
New Product iRangeX RX803 Super Micro Receiver Compatible Frsky D8 X9D Plus SBUS Output-FREE TEST BG Tobey Radios 12 Nov 14, 2017 09:40 PM
Discussion 2.4G 8CH Micro Frsky D8 Compatible Receiver With PPM SBUS Output IKKI Mini Multirotor Drones 2 Jan 08, 2017 07:08 PM
