Mar 09, 2018, 10:23 PM
Barbwire 2, Recoil 17, Vector SR48, and Feilun FT012, speed comparison
Vector SR48 with upgraded motor and Gens Ace lipo (24mph)
Volantex V797-3 (Vector SR48) speed test w/3500kv motor (5 min 48 sec)
Mar 09, 2018, 10:25 PM
Feilun FT012 all stock (24mph) and with Gens Ace 3s lipo (26mph)
Feilun FT012 speed test (stock battery vs Gens Ace) 3-4-18 (4 min 24 sec)
The battle....
Feilun FT012 vs Volantex Vector SR48 3-4-18 (2 min 2 sec)
Mar 09, 2018, 10:27 PM
Pro Boat Recoil 17 100% all stock 24mph
Pro Boat Recoil 17 stock speed test (1) 3-8-18 (2 min 21 sec)
Mar 09, 2018, 10:59 PM
Pro Boat Recoil 17 all stock with Gens Ace 3s lipo (28mph)
Pro Boat Recoil 17 stock speed test #2 (28mph) 3-9-18 (2 min 48 sec)
Mar 10, 2018, 12:52 AM
Just Plane Nutts
AirDOGGe's Avatar
The Barb-2 with the new larger motor should take the win.
I think there was no gain with the 3500KV swap in the Volantex because the physical motor size stayed the same, so torque was actually reduced. It gained little to no advantage over stock.
Try a 3500-3700KV of the same diameter, but with a longer can/stator. This one would bolt right in with M3 screws (19mm hole spacing matches stock motor mount): https://www.ebay.com/itm/NEW-2835mm-...4383.l4275.c10
Due to the slightly larger shaft, the stock coupler would need to be drilled out on one end from 3.0mm to 3.17mm (1/8th inch). Or drop in a new2.3mm to 3.17mm coupler like this one: https://www.ebay.com/itm/2-2-3-3-3-1...SZkzsXUVLl2xjg
You would also want to upgrade to a 50A-60A ESC. THEN you'd have a competitor to pursue.
Mar 10, 2018, 01:44 AM
Lot of good info there DOGGe Thanks! I gained 4mph by just putting the 3500kv in the Volantex. My best speed was 20-21mph with the stock motor in it. I'll look for the video and upload to YT. It was a dramatic difference between the two for me. I guess I could have had a bad motor though. As for the Barbwire 2 the fastest I've seen one go was 27mph on YouTube from a reviewer. Maybe I can somehow match his numbers....
Mar 10, 2018, 04:52 PM
Just Plane Nutts
AirDOGGe's Avatar
24mph-25mph was the claim for the old Barb, so sounds about right. The XL was rated at 27mph stock.
Mar 10, 2018, 06:15 PM
Good info.
Mar 13, 2018, 09:14 PM
Still great Kite flying weather here! But I did try my Volantex Vector out today and got 33mph from the logger with the upgraded motor and 30mm prop.
Volantex V797-3 (Vector SR48) speed test#2 w/3500kv motor (33mph) (1 min 13 sec)
Mar 14, 2018, 07:20 PM
I'm REALLY liking this new motor and prop combo on the Vector SR-48! I remembered to check the coupler before this run...
Volantex Vector SR-48 full run with speed test (32mph) (4 min 28 sec)
Mar 14, 2018, 07:27 PM
Fast electric boats maybe
Jeffro Bodine's Avatar
Mark , I got a couple 32mm detonged and back-cut metal props for those hulls that you can try and get some more speed out of them .
Mar 15, 2018, 06:14 AM
Great reviews of popular boats which are easily accessable to many which keeps the hoby afloat(oh dear!) So neat and relatively easy(hopefully) mods too. Really enjoyed the clips. I would point out to newbies though that the purchase price of a ft012 or volantex is CONSIDERABLY less than the Proboat or Barbwire. Which does leave a bit more cash in you pocket when yougo for these tempting modifications.
Mar 15, 2018, 11:34 AM
Just Plane Nutts
AirDOGGe's Avatar
How did you jump from 24mph to 33mph with the SR and 24 to 28mph with the Recoil? Was the GPS working correctly?
Mar 15, 2018, 05:47 PM
Ran the FTO12 today the first run of the year so far and got 31mph out of it with the 3 year old stock lipos , Mark what mah and c rating are those Gens-ace lipos , I need to get something better and newer for her and get a couple more mph out of it.
Mar 15, 2018, 06:23 PM
Thanks!
GPS is spot on accurate.
(SR) added a30mm prop and a little fine tuning (heating and bending) on the trim tabs and sanded the rudder a little.
Recoil stock battery 24mph...Gens Ace 28mph
Discussion UDI tempo 17... brushed atomic barbwire/pro boat recoil? (same as react 17) dacaur Micro and Sub-Micro Boats 4 Apr 21, 2017 09:45 PM
Careful! Feilun ft012 quality crap atm! ( 2 in1 esc not working properly) Fizman Racing Boats - Electric 1 Aug 18, 2015 02:38 PM
Discussion Proboat Recoil 17 or Barbwire help RCScott Racing Boats - Electric 3 Jul 07, 2015 09:04 AM
