This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Mar 09, 2018, 09:49 PM
old4570's Avatar
Mini-Review
2.4G 4CH Mini Frsky D8 Compatible Receiver With PWM Output ( PT1 )
2.4G 4CH Mini Frsky D8 Compatible Receiver from Banggood
Description:
Item Name: 2.4G mini receiver ( $7.99 USD )
Channel: 4CH
Weight: 2.2g
Resolution: 1024
PWM Output: Yes
Operating Voltage: 3.5-10V
Current: 50MA
Antenna Length: 100mm
Dimension: 11mm*24.5mm
Control Range: >500M+
Compatibility: Compatible with frsky X9D (D8 Mode), XJT (D8 Mode), DJT, DFT, DHT
I got myself the smallest Rx I could find that will accept plugs from normal servos ..
I was surprised at just how small it is .
The servo connector wires / posts (?) need to be soldered to the board .. ( They should be pre soldered ) But !
This Rx is so light , some one may wish to solder the servo wires directly to the board to save weight .
The last picture shows my soldering !
Next I will bind to my Taranis Q x7 ( hopefully ) and range test the Rx ( Part 2 )
Mar 09, 2018, 11:01 PM
old4570's Avatar
It be stinky hot outside ...
36 deg C ... I am not going out there ( sorry )
I bound the Rx to my Taranis Q x7 = Easy .... And then made a range test box . ( Pictured )
Bind process ....
I went into the menu of the Q x7 and created a new model ..
Then set the transmitter to D8 ( 1-8 ) mode ...
Then set the Tx into bind mode :
With the Tx in the bind mode :
Rx .
I had connected a UBEC to Ch1 and a servo to Ch4 ..
Before applying power I press and hold the bind button and whilst holding the bind button apply power to the Rx .
The bind is almost instantaneous ...
I let go the bind button and disconnected power to the Rx ... ( Get the Tx out of bind mode )
Turning on the Rx again - it was bound to the Tx ...
Tomorrow should be much cooler than today ( 12 deg C cooler ) and I will then range test the Rx ...
Apr 23, 2018, 03:32 PM
Scratch Builder
TrooperCooper's Avatar
Looks great! I saw your review on Banggood! I want one of these for my Baby Baron, but I dont wanna have to wait for it to ship from China. How long did yours take? They also have some on Amazon, but probably not much better there.
Apr 23, 2018, 06:42 PM
old4570's Avatar
Usually takes a little over a week ..
If its out of stock ? Then maybe a lot longer .
Too many variables , but plan on a week .
May 14, 2018, 06:21 PM
Do you have a range-test result yet? I have a couple of these, but have only flown in a tiny glider. Thanks!
May 14, 2018, 07:08 PM
old4570's Avatar
https://www.rcgroups.com/forums/show...t-2-Range-test
New Product 2.4G 8CH D8 Mini FrSky Compatible Receiver With PWM PPM SBUS Output --FREE TEST BG Tobey Radios 46 Aug 14, 2019 04:49 PM
Discussion Flysky FS2A 4CH AFHDS 2A Mini Compatible Receiver PWM Output for Flysky i6 i6X i6S scousethief Banggood.com 3 Apr 09, 2018 10:04 AM
New Product iRangeX RX803 Super Micro Receiver Compatible Frsky D8 X9D Plus SBUS Output-FREE TEST BG Tobey Radios 12 Nov 14, 2017 09:40 PM
Mini-Review AKK 901 2.4G 4CH 6 Axis Mini Quadcopter One Key Return Compatible with AKK A1 Micro C siriusflier Micro Multirotor Drones 2 Apr 29, 2017 06:18 PM
Discussion 2.4G 8CH Micro Frsky D8 Compatible Receiver With PPM SBUS Output IKKI Mini Multirotor Drones 2 Jan 08, 2017 07:08 PM
