Mar 20, 2018, 06:39 PM
Walmart has these in the Sporting Goods department alongside camping supplies. 12 in a pack for 88 cents.
Mar 23, 2018, 03:25 PM
It “seems” like a bent (but not to the point of being broken) skewer is more rigid that a straight one. Anyone else find it that way?
Mar 24, 2018, 07:22 AM
Extreme Sports's Avatar
Any nominally rigid material will behave like that. Initially only a small force is needed to deflect it. More force is needed to deflect it a long way, so it feels 'stiffer'. Problem is that only a little bit more force is needed to reach the stress level where it fails. I don't think I'd use this 'technique' for a spar, but 'pre-stressing' a structural component is used in the engineering world.
Apr 01, 2018, 04:37 PM
Check out this thread if you would like to- Not need a spar- https://www.rcgroups.com/forums/show...ovement/page42
I like the smaller skewer sizes for stiffening areas of foam or repairing.. Just use a sharpened brass tube to cut the hole- slather some glue onto skewer- push into hole. I prefer the foaming gorilla glue for this. It fills all the voids in the foam as it expands.
Check "sandwich theory" on wikipedia. A foam wing core with outer skin is a composite sandwich- surprisingly strong-relatively light.
Jun 22, 2019, 07:26 AM
People seem to ignore the fact that aluminium is very light, very workable and very strong. Simply put a right angle bend in a length of aluminium strip and its strength is massively increased and its unwillingness to bend. It can then be glued into a thin slit in the foam.
Martin
Jun 25, 2019, 08:34 PM
I Look, Listen, and Learn
Timbo383's Avatar
I have used both cf and bamboo in many of my planes and one thing that shocked me was that when I weighed a same size of cf rod to bamboo it was almost the same weight, granted the cf is 10 times stiffer tho. Bending a bamboo rod like GPW states creates a stiffer rod when it is cured, I'm guessing the arc in it aids in the stiffness. On the 32 or 36 inch bamboos if you cut them in half and glue them together....I use the old thread and epoxy method....for a dihedral wing they make a pretty stiff spar.
Jun 28, 2019, 01:11 PM
[QUOTE=SirRexAlot;39349099]Head down to WalMart, those long BBQ skewers are 88 cents a dozen.
Confirmed- My local wmart has them in the camping supplies- $.88 for 12, 5mmx 36".
Can create dihedral by wrapping a wet paper towel around center- apply heat gun= steam.
New Product Thor 210V2 205mm - 5mm 75g Carbon Fiber X-Frame D Gains Mini Multirotor Drones 0 Jul 17, 2017 05:12 AM
Question Tubes for Carbon Fiber Spars (in removable wings) FPV_Habu_Flyer Scale Kit/Scratch Built 7 Aug 07, 2016 12:44 AM
Cool 100 5mm x 36" bamboo skewers for $28 balsa or carbon Foamies (Scratchbuilt) 2 Feb 09, 2015 06:29 PM
Discussion 1mm carbon fiber plate vs 1.5mm g10 danielpetrescu Scratchbuilt Multirotor Drones 5 Sep 24, 2014 06:56 AM
Carbon Fiber Spar or Carbon fiber skin? soholingo Composites Fabrication 0 Mar 22, 2005 10:35 PM
