This thread is privately moderated by ariaAQ, who may elect to delete unwanted replies.
Mar 09, 2018, 06:00 AM
ariaAQ's Avatar
Mini-Review
Bernoulli 3515 500kv Integrated Motor with ESC and Led Light
Hello, this is my test and review about new Bernoulli 3515 motor from Inspired Flight.
Bernoulli 3515 500kv Integrated Motor Built in ESC & LED light - Thrust Test and Settings (12 min 36 sec)
First impressions:
- Really nice build quality.
- Super smooth bearings.
- Bright LED,
- A lot of accessories,
I need to know about the motor in real flight situation, not only the max thrust in perfect lab situation.
So my test using partially charged old batteries and 1447 carbon fiber props.
I think this represents a motor performance: in the middle to the end of the flight.
Test result with 6S batt + 1447 props:
- 770g (40%, 4.19A)
- 890g (45%, 5,36A)
- 990g (50%, 6,16A)
- 1090g (55%, 7,25A)
- 1220g (60%, 8,72A)
Its safe to say 900-1100g = recommended weight per motor. (1200g should be no problem in calm day situation)
Based on 8 minutes test, temperature never reach 47C, so motor capable to use bigger props if more thrust needed.
Unfortunately I don't have 15" and 16" props. I just have 12", 14" and 17" to test with the motor.
I will post my test with 12" + 6S later (maybe 17" with lower batt setup)
Motor: https://www.inspiredflight.com/produ...t=991685148678
Mfr specs:
Motor Size: 3515
RPM per Volt: 500 kV
Shaft Size: 4 mm
Weight: 167g
Input Voltage Range: 10V - 25.5V
Recommended Battery: 4s - 6s LiPo (14.8v - 22.2v
Continuous Current: 20 Amps (500W)
Burst Current: 35 Amps (875W)
Mounting Bolt Pattern: 16x19, 19x25, & 25x25
Recommended Prop*:
Multirotor: 12-inch to 15-inch Diameter, 3-inch to 5-inch pitch
Fixed Wing: 9-inch to 13-inch Diameter, 5-inch to 9-inch pitch
Recommended Aircraft Weight*:
Multirotor: Up to 1.5 KG (3.3 lbs) per motor
Fixed Wing: Up to 4 KG (8.8 lbs) per motor
Each Bernoulli comes with:
Bernoulli 3515 Integrated Motor
Prop Adapters: 6 mm Threaded Post and T-Style
50 cm Long Pre-Soldered Power Cable w/ XT30
30 cm, 50 cm, or 75 cm long Signal Cable (specify above)
Mounting Screws
The pics and test result:
Mar 09, 2018, 06:03 AM
ariaAQ's Avatar
Go to 2nd test for more info:
https://www.rcgroups.com/forums/show...-1248-and-1447
New Product Bernoulli 3515 Brushless Motor - Integrated ESC and Nav Light MarcRacer18 Scratchbuilt Multirotor Drones 6 Mar 22, 2018 08:36 AM
Article Contest! - Bernoulli 3515 Integrated Motors Jim T. Graham Multirotor Drone Talk 96 Mar 08, 2018 07:11 AM
New Product Bernoulli 3515 Motor - Integrated ESC & Nav Light MarcRacer18 Power Systems 4 Feb 16, 2018 02:22 AM
New Product Bernoulli 3515 Brushless Motor - Integrated ESC and Nav Light MarcRacer18 Multirotor Drone Talk 0 Feb 15, 2018 05:19 PM
