RX100, RX120, RX120-2S framakit with preassembled tail. - RC Groups
This thread is privately moderated by remlen, who may elect to delete unwanted replies.
Mar 08, 2018, 09:33 AM
roman-nikolenko.com
remlen's Avatar
I want to thank Mike Jennings (MikeHRC) for the translation!!!
According to the numerous requests of all comers, the models of the three frames RX100, RX120 and RX120-2S with preassembled tail will be available.
In the future, I hope to expand the model range to larger models, but for now I'll tell you more about the models mentioned above.
RX100
The kit consists of an assembled frame, with installed skids, a tail motor and all the mechanics of the tail rotor. The kit also includes a spare tail hub, a tail fin and a servo holder. In addition to the spare parts in the kit there is a 1 mm diameter carbon rod, it can be glued into the frame, into a special hole, near the main engine, to protect the canopy from the engine.
For final assembly of the model you will need:
- Helicopter Controller Board K110 or V977. https://www.banggood.com/XK-K110-RC-...r_warehouse=CN
https://www.banggood.com/WLtoys-V977...r_warehouse=CN
The control board from the K123 / V931 helicopter is not suitable!
- three servos size 5330
https://hobbyking.com/en_us/hk-5320-...c-0-075kg.htmlServo drive size 5330 (servo from K110 / V977) can also be installed, but for this model I recommend using lighter servos 5320.
- Main motor size1105/1106 of 14000-16000kV. Recommended motors - HP05S of 14000kV http://www.overskyrc.com/hp05s-brush...00kv-p-61.html
- Main motor ESC, suitable - ESC MX10A. https://hobbyking.com/en_us/brushles...elicopter.html or the ESC from the K110 or V977
- Tail rotor ESC / suitable ESC MX3A. https://hobbyking.com/en_us/supermic...-3a-mi-3a.html
- Pinion for the main engine. I recommend pinion for 9 teeth with module 0.5, hole for shaft diameter 1.5mm
https://hobbyking.com/en_us/micro-he...r-0-5m-9t.html
- Maingear of 61 teeth with module 0.5. A gear from a Walkera Mini CP helicopter http://www.ebay.ca/itm/Walkera-HM-Mi...EAAOSwol5Y4ypW
There will also be a variant of the frame for the maingear of 64 teeth from the helicopter K110 or V977. https://www.banggood.com/XK-K100-K11...gCZ1MMMT3Z59My
- Main shaft with snap ring. The shaft diameter 2.5mm is 52-53mm long. Suitable main shaft from the helicopter K110 or V977, but with a slight modification. I recommend using a carbon core shaft, slightly shortening it.
https://www.banggood.com/WLtoys-V966...r_warehouse=CN Or make the shaft itself from the carbon rod.
- Two main shaft bearings from the K110 or V977 helicopter. Size of bearings 2.5 * 6 * 1.8 https://www.banggood.com/XK-K100-K11...l?rmmds=search
- Main Rotor / Head. The rotor hub, the swash plate and the main rotor grips from a K110 or V977 helicopter. I strongly recommend using high-quality metal parts in this node.
https://www.banggood.com/XK-K110-K12...r_warehouse=CN
- Feathering shaft from the helicopter K110 or V977. https://www.banggood.com/XK-K100-K11...l?rmmds=search
- Dampers and thrust washers for head from a helicopter K110 or V977.
- Swash and Main grip links for K110 or V977 https://www.banggood.com/XK-K100-K11...r_warehouse=CN тяги нужно укоротить!
- Main blades for WLToys V977or K110. https://www.banggood.com/XK-K110-K10...r_warehouse=CN https://www.banggood.com/WLtoys-V977...l?rmmds=search
- Recommended canopy from the helicopter V966. https://www.banggood.com/WLtoys-V966...l?rmmds=search
In the end, you should get a similar helicopter
More details on the assembly of a helicopter on this frame can be found in the articles of my diary.
Second part - http://forum.rcdesign.ru/blogs/198531/blog22649.html
First part - http://forum.rcdesign.ru/blogs/198531/blog22246.html
I want to note important features.
The drive shaft of the tail rotor of this model does not have a central sleeve inside the tail boom.
Skis in this model - it is shortened to 4mm skis from the helicopter K110 or V977.
If you need to replace the skis, you will have to make them yourself.
This model uses the maingear for 61 teeth from the Walkera Mini CP helicopter.
This gear is quite difficult to find on sale, so if desired, two versions of this frame will be available.
The first option for a maingear of 61 teeth from a helicopter Walkera Mini CP
The second option is a maingear of 64 teeth from a helicopter K110 or V977.
RX120
The kit consists of an assembled frame, with installed skids, a tail motor and all the mechanics of the tail rotor. The kit also includes a spare tail hub, a tail fin and a servo holder. In addition to the spare parts in the kit there is a 1 mm diameter carbon rod, It can be glued into the frame, into a special hole, near the main engine, to protect the canopy from the engine.
- Helicopter Controller Board K110 or V977. https://www.banggood.com/XK-K110-RC-...r_warehouse=CN https://www.banggood.com/WLtoys-V977...r_warehouse=CN
- Three servos from helicopter from K110 or V977 size 5330. https://hobbyking.com/en_us/hobbykin...4sec-1-9g.html
- Main motor size1105 / 1106 of 14000-16000kV. Recommended motors - HP05S of 14000kV, or HP06S of 16200kV. http://www.overskyrc.com/hp05s-brush...00kv-p-61.html
http://www.overskyrc.com/hp06v2-1620...otor-p-60.html
- Main motor ESC, suitable - ESC MX10A. https://hobbyking.com/en_us/brushles...elicopter.html Or the ESC from the K110 or V977
- Pinion for the main engine. I recommend pinion for 8 or 9 teeth with module 0.5, hole for shaft diameter 1.5mm. https://www.banggood.com/XK-K110-K12...r_warehouse=CN https://hobbyking.com/en_us/micro-he...r-0-5m-9t.html
- Maingear of 64 teeth with module 0.5. Suitable gear from the helicopter K110 or V977. https://www.banggood.com/XK-K100-K11...-p-992579.html
- Main shaft with snap ring. The shaft diameter 2.5mm is 52-53mm long. Suitable main shaft from the helicopter K110 or V977, but with a slight modification. I recommend using a carbon core shaft, slightly shortening it. https://www.banggood.com/WLtoys-V966...r_warehouse=CN Or make the shaft itself from the carbon rod.
- Two main shaft bearings from the K110 or V977 helicopter. Size of bearings 2.5 * 6 * 1.8. https://www.banggood.com/XK-K100-K11...l?rmmds=search
- Main Rotor / Head. The rotor hub, the swash plate and the main rotor grips from a K110 or V977 helicopter. I strongly recommend using high-quality metal parts in this node. https://www.banggood.com/XK-K110-K12...r_warehouse=CN
- Dampers and thrust washers for head from a helicopter K110 or V977. https://www.banggood.com/XK-K100-K11...-p-992580.html
- Swash and Main grip links for K110 or V977. https://www.banggood.com/XK-K100-K11...r_warehouse=CN
The servo to swash links must be shortened!
- Main blades for WLToys V931 or K123.
https://www.banggood.com/WLtoys-V931...p-1047275.html
- Recommended canopy from the helicopter K110 / V977 / V966 https://www.banggood.com/WLtoys-V977...-p-918062.html https://www.banggood.com/WLtoys-V966...-p-917190.html
In the end, you should get a similar helicopter.
Second part - http://forum.rcdesign.ru/blogs/198531/blog21967.html
First part - http://forum.rcdesign.ru/blogs/198531/blog21630.html
The drive shaft of the tail rotor of this model does have a central brass sleeve inside the tail boom.
The sleeve is installed in a boom with a pull.
RX120-2S
[B]For final assembly of the model you will need:[B]
- 150GRS control board and speed controllers from the helicopter Align 150X http://shop.align.com.tw/product_inf...oducts_id=6036
- Main motor size 1106 of 8000-8500kV. Recommended motors - HP06V2 of 82000kV. http://www.overskyrc.com/hp06v2-8200...tor-p-486.html
- Maingear of 64 teeth with module 0.5. Suitable gear from the helicopter K120. https://www.banggood.com/XK-K120-RC-...r_warehouse=CN
- The rotor hub K110 or V977. https://www.banggood.com/XK-K110-K12...r_warehouse=CN The hub must be modified.
- Swash plate K110 or V977 https://www.gearbest.com/rc-helicopt...pp_241175.html
- Main rotor grips from a K123/K124 or V931
https://ru.aliexpress.com/store/prod...6d002794wtiG76 https://ru.aliexpress.com/item/XK-K1...311.0.0.yyTFjL
- Dampers and thrust washers for head from a helicopter K110 or V977. https://www.banggood.com/XK-K100-K11...l?rmmds=search
- Swash and Main grip links for K110 or V977. https://www.banggood.com/XK-K100-K11...r_warehouse=CN The servo to swash links must be shortened!
- Main blades for WLToys V931 or K123. https://www.banggood.com/WLtoys-V931...r_warehouse=CN
- Canopy from the helicopter K110 / V977 / https://www.banggood.com/WLtoys-V977...l?rmmds=search
Third part - http://forum.rcdesign.ru/blogs/198531/blog23185.html
Second part - http://forum.rcdesign.ru/blogs/198531/blog22978.html
First part - http://forum.rcdesign.ru/blogs/198531/blog22702.html
The helicopter based on this frame is designed for operation by the flybarless system 150GRS Flybarless System Set.
This flight controller has excellent characteristics and allows you to configure flight parameters through a mobile application.
However, there are nuances of the operation by this system, which depend directly on the mechanical part of the helicopter.
This system is designed to work with the mechanics of the helicopter Align 150X. The mechanics of the helicopter Align 150 X has other gear ratios, compared with the mechanics of helicopters K110 / V977. Therefore, it is impossible to use the hub, swash plate and main rotor grips from the helicopters K110 / V977, without changes. It is necessary to assemble the mechanics of the helicopter from parts of different models.
The main problem is the insufficient deviation angles of the standard servo drives 5330, when using the 150GRS. Therefore, it is necessary to increase the gear ratio of mechanics. To do this, instead of the rotor grips from the helicopter K110/V977, you must use the DFC rotor grips from the helicopter K 123/ K 124 or V931. These rotor grips have a shorter lever, and accordingly an increased gear ratio.
When using the DFC rotor grips, you must remove the guide link from the hub because there will be no need in these guides and they will interfere with the normal operation of the rotor grips. The swash plate can be left without changes. To increase more the total and cyclic pitch you can lengthen the levers of the servos.
Important features for all models.
For correct operation of the mechanics of the main rotor, you have to shorten the length of the grip links coming from the servos to the swashplate.
The total length of the grip links should be 20.5mm + \ - 0.5mm.
For answers to all questions regarding the purchase of these frames, please go to the group https://www.facebook.com/groups/ROMANHELI/ or write me in skype remlen_j or WhatsApp +380501303758.
Discussion Sample of aerial video with the Sony RX100 SeismicCWave Aerial Photography 66 Apr 17, 2013 08:55 AM
Video Hobby City Preassembled EDF89 with D3468kv JIMinKENTUCKY Electric Plane Talk 4 May 12, 2009 11:58 PM
