New Jeti High Voltage Servos
Jeti has recently introduced a new line of HV servos that should be interesting for those looking for premium quality servos. There are 4 different servos available currently and they feature efficient coreless motors, chrome-titanium gears with a standard 25 tooth (Futaba) output gear.
More Servo Options from Jeti
Jeti has recently introduced a new line of HV servos that should be interesting for those looking for premium quality servos. There are 4 different servos available currently and they feature efficient coreless motors, chrome-titanium gears with a standard 25 tooth (Futaba) output gear. The cases are waterproof and the servos can run on 4.8-8.4V. Most uses will see these running unregulated on a 2S Lipo. These servos run $95 - $150 and are meant to be used in high performance aircraft where speed, power and efficiency matter.
Check out the new line of Jeti Servos at Esprit Model.
Jeti DSHV J3D13T - $95.00
  • Applications: Heli/Airplanes 7.4V (2S)
  • Type: High Voltage Coreless Digital Mini
  • Torque 7.4V: 180.5 oz/in (13 kg/cm)
  • Torque 8.2V: 194.5 oz/in (14 kg/cm)
  • Speed 7.4V: 0.14 sec/60 degrees
  • Speed 8.2V: 0.13 sec/60 degrees
  • Dimensions: 35.5mm x 28.5mm x 15mm
  • Weight: 39g
  • Bearings:Dual Ball Bearing
  • Gear Type/Spline: Titanium/25T/6mm (Futaba)
Jeti DSHV J3D8.5T - $95
  • Torque 7.4V: 118 oz/in (8.5 kg/cm)
  • Torque 8.2V: 132 oz/in (9.5 kg/cm)
  • Speed 7.4V: 0.10 sec/60 degrees
  • Speed 8.2V: 0.09 sec/60 degrees
  • Weight: 39g
  • Bearings: Dual Ball Bearing
Jeti DSHV J4A18.5T - $150.00
  • Type: High Voltage Brushless Digital Standard
  • Torque 7.4V: 257 oz/in (18.5 kg/cm)
  • Torque 8.2V: 285 oz/in (20.5 kg/cm)
  • Speed 7.4V: 0.08 sec/60 degrees
  • Speed 8.2V: 0.07 sec/60 degrees
  • Dimensions: 40mm x 39mm x 20mm
  • Weight: 74g
Jeti DSHV J4A23T - $150.00
  • Torque 7.4V: 319 oz/in (23 kg/cm)
  • Torque 8.2V: 347 oz/in (25 kg/cm)
  • Speed 7.4V: 0.12 sec/60 degrees
  • Speed 8.2V: 0.11 sec/60 degrees
  • Weight: 74g
Mar 09, 2018, 11:50 AM
ltc
ltc
AMA 97737
ltc's Avatar
I don't believe these have soft start capability, which would have been nice.
I use the Jeti/Hacker Ditex servos which are very nice so far.
Mar 18, 2018, 11:51 AM
Torque units are oz.in or kg.cm, not oz/in or kg/cm.
Mar 20, 2018, 04:01 PM
Go Hawks!
cryhavoc38's Avatar
Nitpicky much?
Mar 27, 2018, 05:52 PM
Originally Posted by cryhavoc38
Nitpicky much?
Absolutely. Pet peeve: units matter.
Discussion HIgh Voltage Vs Low Voltage Servos Jdm3go Electric Competition Soaring-F5J/ALES/e-Soaring 24 Jul 16, 2018 09:39 AM
News New Align High Voltage Digital Servos ndfly700 Electric Heli Talk 0 Jul 28, 2016 11:16 PM
