This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Mar 08, 2018, 05:14 AM
old4570's Avatar
Spirit 600 is done ... ( Hindsight )
Spirit 600mm from Banggood ..
https://www.rcgroups.com/forums/show...8-assemble-%29
https://www.rcgroups.com/forums/show...h-that-s-right
https://www.rcgroups.com/forums/show...e-test-fitting
Some hindsight now that the wing is finished ..
I built it as it was designed to be built = WRONG !
My goal was to go light , I did that .. But the weight is in the wrong place ..
It takes a 700mAh 2s to balance the wing .. ( Makes it heavy )
What is required is a complete redesign or relocation of components .
The motor needs to go where it goes ..
But everything else needs to be located near CG ..
I would suggest burying the servos in the wing ... ( @ CG location )
Have as much weight around CG as possible , so a smaller battery can be used ...
Also the 1306 4000kv is overkill .. ( who does not want overkill )
@ 50% throttle with a unknown battery ( voltage state ) I had 1 to 1 power to weight ...
Will there be a 3rd Spirit 600 ( ?????? )
I would want an even smaller motor , maybe 3000kv . Maybe a 6A ESC .
These 3.7g servos seem to be enough , 9g is overkill .
Smallest 4ch Rx ...
Put as much stuff @ CG as possible .. That way the battery has to only offset the weight of the motor ( and ass end of model ) ....
Hmmmmm , now I think about it ( Hindsight )
Discussion Sagitta 600! Get r' done!! Mr.Kiwi Sailplane Talk 8 Apr 14, 2009 08:33 PM
Discussion Filip 600 Sport...suggested power set up for spirited performance? Canada Goose Electric Sailplanes 13 Aug 30, 2008 03:53 PM
Yippee! My Spirit Elite 2m wing span is done :) Anders Moen Sailplane Talk 11 Feb 08, 2008 01:19 PM
Discussion century 600+ on 4s anyone done it miskin Electric Heli Talk 15 Oct 29, 2006 10:56 PM
