Mar 08, 2018, 02:56 AM
Help!
Setting up 3-pos switch
Hi, i am having a hard time setting up my radio (Futaba T9CAP). I need 2 3-pos switches active on my radio for OSD/flight mode changes.
I have set up switch C for flight modus (manual, stab, rth), and i would like to set up switch E for OSD setting changes. But......... i can't get it to work.
Switch E is a 3-pos switch, which acts like a 2-pos switch, it does neutral/min/min or max/max/neutral. The label next to te switch does show a different configuration of the switch, max/neutral/min but i can't get the switch to act like that.
Is there someone who is able to help me out on this matter, or is it just not possible in acrobatic (plane) mode?
Thanks in advance, looking forward to some suggestions.
Kind regards,
Ron
Mar 10, 2018, 11:58 AM
Issue is solved. Switch F and pcd behind both switches E and F is broken.
De solderded switch F and solderded the wires directly to switch E.
Now it acts like a 3-pos switch.
Now it is working, without switch F.
Help! How to connect a Stick switch with 3-pos. switch and push button for X10S? liukku FrSky 7 Feb 04, 2018 12:43 PM
Idea Simplify Betaflight in-flight adjustments with 3x 3-pos switches Mr MultiRotor 88 Multirotor Drone Electronics 0 Oct 20, 2016 04:32 PM
Discussion Taranis 3 way switch set up Leftyatm Beginner Multirotor Drones 2 Aug 12, 2016 07:42 PM
Help! Setting up 3 pos. flaps on my 1400mm FMS P-51 wks01954 Electric Warbirds 0 Mar 28, 2013 03:54 PM
Question how to set up on chanel 5 aux1 6 pos switch oren_ben_nun Hitec/Multiplex USA 0 Jul 22, 2012 05:49 AM
