Mar 07, 2018, 09:26 AM
larryoakley's Avatar
VAS 2.4 Folded Dipole
I realized I have to use an SMA female to RP-SMA male adapter to use in my Horus radio (not sure why VAS/Alex decided to build this antenna using an SMA male instead of the normal RP SMA male like the rest of compatible antennas).... in any case, I was wondering if, on top of the usual DB loss due to the extra adapter (which by the way defeat the purpose of a higher gain antenna), is the SWR also increases because the cable/antenna distance also change??
Anybody else using this antenna? whats your thoughts
Discussion VAS 2.4 folded dipole Axiom7 Radios 30 Jun 21, 2018 06:20 AM
Discussion Should the vas dipole have continuity to ground on both elements? Jmel FPV Equipment 5 Aug 31, 2017 11:37 PM
Discussion Make a simple"dipole 2.4 ghz antenna" géry 46 Scratchbuilt Multirotor Drones 7 Dec 20, 2015 06:49 PM
Discussion Make a simple"dipole 2.4 ghz antenna" géry 46 Multirotor Drone Electronics 0 Dec 19, 2015 05:40 AM
Discussion any body using a VAS UHF Coil Loaded Dipole 433 MHz? yosemitez Multirotor Drone Talk 0 Jul 17, 2015 06:34 PM
