DIY S.bus Hub - RC Groups
Mar 06, 2018, 11:31 PM
DIY S.bus Hub
Hi, I just got a new Futaba S.bus setup with high voltage servos (Mostly Futaba S3072HV's)
The s.bus hubs are somewhat pricey and why would I not use regular or home made Y harnesses?
This is my 1st 1/4 scale plane / 1st foray into s.bus and gas power but it's far from being my 1st plane.
The plane is a 30 C.C powered 1/4 scale Sig Cap 231 EX I bought for a song at a swap meet many years ago.
I understand that using the Futaba hubs you can plug-in additional batteries to keep all servos juiced-up but I don't think it's necessary with this setup: 6 servos with 2 elevator, 2 ailerons / throttle / 1Rudder.
The battery also has to power the ignition for the engine (OS GT33) I will probably go with a 2s 2600mah lipo to power all of the above.
So bottom line:
- There should be no reason why either a home made harness or regular Y harnesses would not work right? (I bench tested s.bus with 2 y harnesses / 3 servos there were no issues)
- 6 servos even if they are high torque / high voltage should not require more than 1 battery pack right on a plane that size right?
- The receiver / servos are designed to run on 2s lipos and so is the O.S Ignition module. I'm not planning on using a regulator. Am I right to assume that one 2s 2600 mah LiPo will get the job done?
Thanks in advance.
R/C Phile.
Mar 07, 2018, 02:49 AM
Could get better answers in DIY Electronics forum...
Discussion FrSky D series arduino DIY hub with naza GPS data to openTX poteroa Radios 65 Jun 19, 2018 02:35 PM
Help! DIY FrSky Sensor hub Mike Meyer DIY Electronics 0 Sep 18, 2015 09:38 PM
Question Futaba S.Bus power hub HotAir2 Radios 5 Jan 30, 2015 02:05 PM
